![]() | Home > Technical (L322) > Suspension 'locked' in extended mode |
| duka Member Since: 11 Jan 2011 Location: uk Posts: 147
car decided to raise itself into extended mode and now can't be lowered. the display has two front sensors in red below the image of the wheel & evey toime try to activate the suspension knob error massage on the dash stated SUSPENSION FAULT
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
A dealership would be the best way as its still under warranty and you may be able to call LRA out to fix it with their test books. FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
unfortunately it's not under warranty as its 2006 car |
Ahh just confused me as the profile you have has a 2010 on it |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35877
try battery dis/re-connection, it might reset the ecu.. ... - .- -.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
You have got all the doors shut when you try to change the height? |
and another thought, you havnt pressed the 'lock' button accidentally.. ... - .- -.
IIRC for the 2006 systems you cant lock in extended mode |
I think it's an ECU / sensor or compressor problem.
I think that's the biggest issue that needs sorting first!! Seriously if the battery method doesn't wor then a diagnostic will be needed. Also check the sensors maybe give then a light wash and spray on some lithium grease Mantec Sump Guard, Rigid Load liner, MY10 BT upgrade. |
looks like a pressure releif valve is not venting when command is sent & front o/s sensor is intermittent, there didn't seem to be anything on wiki on checking/changing - anyone have any guidance on do's/dont's before I get in about at the weekend?
| All times are GMT |
