![]() | Home > Technical (L322) > Bi Xenons or not |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16341 ![]() ![]() ![]() |
Do they have Bulbs with a black top on or are they a chrome cover? If a chrome cover then your car is not equipt... If a bulb then either you fall into the category "they have never worked from factory" or something has broken... Do your lights move from side to side round bends at night?
Cash2 Member Since: 14 Jul 2012 Location: Essex Posts: 75 ![]() ![]() ![]() |
Hi Craig the bulbs have a black top and no the light does not move from side to side round bends at night. |
Then unfortunately sir them dont work!
Does anyone have any suggestions or a starting point for testing or checking?
Lighty Member Since: 15 Oct 2012 Location: Manchester Posts: 7 ![]() |
Do you have two big Ballast units 1 outside each light? Should have a sticker on it woorning of high voltage, be very careful working around Xenon ballasts as there is a nice 20,000 Volts in there that will hurt you a lot! |
Hi Craig I may have been hasty and misinformed you as to the colour of the bulbs - they looked black when I first looked but having looked again they appear chrome.
I think you will find you are looking at the blanking plugs for the cornering lights, they have nothing to do with the bi-xenon’s they are in fact part of the adaptive system, if your car has it, the adaptive system works with your head lights and moves the head lamp lens, you will see this when you start your car with the lights on, if you are close to a wall you will see the lights move up and down then left and right, if you have this the you may have cornering lights and these work at low speed when turning, IE going into a drive or out of a car park. You are looking for halogen bulb, they can be seen quite clearly, and if you can’t then I would say you have the blanking plugs fitted,
If they are chrome then they are blanks my friend... Craig ![]() |
Thanks to all for the replies |
