Home > Maintenance & Mods (L322) > Exterior Design Pack Rear Bumper
Bigkev
England 2010 Range Rover Vogue SE TDV8 Santorini Black
Evening all,
I am picking my EDP rear bumper up from the spray shop tomorrow and want to get it fitted ASAP but before I dropped it off I tried swapping the parking sensors over and came across what may be a problem?
When I fitted the PDC sensor into the EDP bumper they weren't flush, now I don't know if they are supposed to be or not?
If you look into the back of the bumper at the sensor holders there are 2 half moon tabs at the top but none at the bottom, this is what is causing the bottom of the sensor to protrude through the bumper further than the top.
Pictures as follows:
Can anyone with the EDP rear bumper confirm if the sensors should be flush?
I have spoke to dan at duckworths and he cannot find a part number for the sensor holders so I can't confirm if these are right that way.
Another thing that may be effecting it might be my parking sensors, my car is a MY10 so I am assuming they are a straight swap but can anyone confirm this also.
Picture of one of my sensors:
Many thanks in advance
Kev
Post #149415 2nd Nov 2012 12:43am
chris595959
2015 Range Rover Autobiography 5.0 SC V8 Mariana Black
Hi Have recently fitted genuine body kit and had exactly the same problem . Checked with parts dept there are no other sensors fitted . So I went with it and yes they don't sit flush but not noticeable when fitted to vehicle
Post #149421 2nd Nov 2012 8:33am
Bigkev
Thanks chris, think I will just fit it and see.
It's annoying as my next door neighbour has a my12 with the EDP fitted from the factory but he's away at the moment so I can't check.
I have just finished fitting my new tow bar(a lot easier than I expected) so will be going to pick the stuff up from the paint shop shortly, I'm like a kid at Christmas.
Kev
Post #149439 2nd Nov 2012 10:33am
Kev
Build the exhaust kit on a bench before you install it after fitting the bumper, makes it easier... Also, use alot of copper grease on the exhaust nuts bolts etc as when you need to remove it it will come apart again... Have you bought the working tails or the blanks? SC kit works TDV8 blanks/dummy tails
Oh and yes the parking sensors do fit like yours have...
Craig Thumbs Up
Post #149570 3rd Nov 2012 1:56am
Bigkev
Craig thanks for the reply.
I have the bumper 95% finished the sensor look fine, I am struggling with the exhaust finishers, I seem to have a lot of bits left over which I cant see how they fit anywhere.
Also on the drivers side where the towing loop is I can't get the finisher on as the loop is in the way?
Any advice much appreciated, I will post some pics tomorrow as I am just off out for the day.
Thanks!
Post #149590 3rd Nov 2012 12:12pm
Bigkev
Forgot to say I have the tdv8 finishers with the blanks.
Post #149591 3rd Nov 2012 12:14pm
Grinder Whistle
Post #149609 3rd Nov 2012 3:13pm
The towing loop should fit inside the top left corner (as you look at it from behind)
Have you fitted the passenger side yet? If not, do that one first making sure all the torq screws/bolts fit into the bumper then you can copy what you did on the drivers/harder side...
Craig Thumbs Up
Post #149648 4th Nov 2012 12:09am
