![]() | Home > Maintenance & Mods (L322) > Exterior Design Pack Rear Bumper |
| chris595959 Member Since: 09 Jan 2012 Location: Brighton Posts: 71
Hi Have recently fitted genuine body kit and had exactly the same problem . Checked with parts dept there are no other sensors fitted . So I went with it and yes they don't sit flush but not noticeable when fitted to vehicle |
| Bigkev Member Since: 20 May 2012 Location: Cheshire Posts: 37
Thanks chris, think I will just fit it and see.
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Build the exhaust kit on a bench before you install it after fitting the bumper, makes it easier... Also, use alot of copper grease on the exhaust nuts bolts etc as when you need to remove it it will come apart again... Have you bought the working tails or the blanks? SC kit works TDV8 blanks/dummy tails Oh and yes the parking sensors do fit like yours have... Craig |
Craig thanks for the reply.
Forgot to say I have the tdv8 finishers with the blanks. |
| Alistair Member Since: 11 Feb 2011 Location: Peterborough / Alicante / Andorra Posts: 8135
Grinder |
The towing loop should fit inside the top left corner (as you look at it from behind)
