![]() | Home > Technical (L322) > Should i change gearbox oil or leave it be?... |
Yes have it flushed and new filter and ATF |
marcoos_1 Member Since: 25 Oct 2012 Location: Glasgow Posts: 138 ![]() ![]() ![]() |
Absolutely........well worthwhile.........you'd kick yourself if you don't and god forbid something went wrong.
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 ![]() ![]() ![]() |
I agree, may as well change the oil whilst it's in. |
JPS Member Since: 10 Sep 2012 Location: South East England Posts: 565 ![]() ![]() |
Cheers guys, I just wondered if there were any negative effects on changing the box oil. I'll get them to do it I think and the filter to |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383 ![]() ![]() |
I don't beleive the scaremongers who think it's unwise to change the oil. Does your car break down after an oil service? No. It lasts longer and runs better.
Hi, I've not heard of this 'megaflush' how do they do this and how can I find out if there's someone in my area? Also is it possible to check the level of the fluid yourself? Many thanks. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1039 ![]() ![]() |
There’s a school of thought that, because ATF has a high detergent content, there’s a risk that the new fluid will clean out all the crud that’s come off the clutch plates, bearings, bushes, etc. over the years - that’s currently sat lodged in the various nooks and crannies in the transmission casing where it’s doing no harm - and send it through the valve block causing the transmission’s hydraulic control system to subsequently fail.
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3818 ![]() ![]() |
Phil, logically I agree with you.
