![]() | Home > Technical (L322) > Battery Light comes on for 30 -60 secs after startup |
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Could be a bad connection on the battery or alternator but the chances are the advice you have been given re the alternator is correct. |
| Buz1500 Member Since: 05 Sep 2011 Location: Cumbria Posts: 369
I've just run up the diagnostic screen and checked the voltage.
| CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528
| mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267
My battery is 12.7v with engine off...
| RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383
If it is the alternator (and the Dealer will be able to tell you) best get it done before it fails somewhere remote. Mine went when I was 650 miles from home in NW Sutherland, and I had to limp home with multiple electrical sensors going off, no lights, dash etc and doing the standard restart process to get it home.
| simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650
Don't trust the onboard diagnostic screen! For some reason voltages are never very accurate on this (at least they aren't on mine anyway).
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Buz where in Lancs are you as i may not be too far away and you can pop round for a quick test if you need? FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
| dogswick Member Since: 14 Jan 2012 Location: ever sunny yorkshire Posts: 20
Mines been flickering the alternator light on for the last 3 years. and that's when I put the cable back on that the previous owner had unclipped. It does it randomly or when I've just started or when I turn the lights on. I am jumping to the conclusion that there's something probably amiss with whatever controls the dash light in the alternator, something daft like a dry joint. I haven't got round to pulling it out to have a look yet. The output is as steady as a rock and I've even had my datalogging scope on to check it but there's no correlation with the flickering light. I would like to say don't worry about it but the second I do it'll probably jack in! |
Hi Kingpleb, I'm in Hoghton, mid way between Preston and Blackburn.
Had another issue today, got 2 miles down the road and got a serieis of warning chimes and messages on the dash. Stuff like suspension lowering, limp home mode etc...I stopped the car and switched if off and on and everything returned to normal.
Hi buzz
Hi Simon,
PM Sent |
PM Sent |
| All times are GMT |
