![]() | Home > Technical (L322) > EML on - bank 2 running lean. |
jfb1977 Member Since: 29 Apr 2012 Location: Bury St Edmunds Posts: 563 ![]() ![]() ![]() |
So my EML came on about a week or so ago.
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
I used to get it on my 2006 S/C, both before, and after I got it converted to lpg. People will often blame an LPG installation for it coming on, but from my research it just seems to be a common problem that it comes up as an erroneous fault.
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 ![]() ![]() |
I had the same issue on mine - ran some BG44K fuel cleaner through it and it's been fine since - there was a TSB from land Rover to try that cleaner if you get this issue - I also put it down to running cheap supermarket fuel.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Have come across this a few times... Normally down to dirt in fuel/tank/lines... Back to the old argument of supermarket fuels im afraid... Put a very good quality cleaner through the system and maybe change your fuel station (if you mainly use the same one week on week)
Thanks for the replies guys.
After having run a couple of cans of BG44k through it I now generally fill her up with Tesco 99 momentum - although it's supermarket fuel, it comes from a different 'holding stock' to the regular unleaded.
The situation with mine is a bit unique, no access to top quality fuel and 2 years of sitting still in a tropical country prior to me taking ownership must have done something to the fuel system. Plus recently running the tank empty probably didn't help either.
So took the car back to my indy today. They suggested a few cans of fuel system cleaner before they start pulling things apart and burning hours looking for faults too.
npikey Member Since: 14 Nov 2011 Location: Lincolnshire Posts: 59 ![]() ![]() ![]() |
I've had the same problem on my 06sc, |
Yes please mate - can you PM it to me.
Mine supposedly has the latest engine software but not the gearbox software (Faultmate, Blackbox provides the files from Land Rover as part of the service. So I can reflash all the necessary ECUs and when I checked the other day, my EMS is up to date). May be the crap quality fuel here.
