Home > Technical (L322) > TPMS valves
Hunttheshunt
United Kingdom 2007 Range Rover Supercharged 4.2 SC V8 Java Black
TPMS valves
Hi, I've had the SC a couple of months now, and touch wood, apart from a couple of small things, it has been plain sailing.
I needed a BT upgrade to get the iPhones to sync properly, a third set of headphones for the RES, the front tow eye cover and a replacement Venture Cam, now all done thanks to FULLFATRR and Fleabay!
I stopped in at the local garage to top off the air in the tyres, and yes you guessed it, one of the valves made a bid for freedom along with most of the air. Like an idiot I sat there for a few seconds with my finger over the remains of the valve!! Called the RAC to change the wheel, it was dark, wet and I've heard the jacks can be like cheese!
Anyway, I have bought a couple of new valves from the 'Bay', £19 each, I hope they work, 433Mhz?? My question is, can I simply take the new valve and the wheel to my local Kwik Fit??
The only other little funny I have is with the Radio/Ventilation. When Max is pressed the Radio loses its tuning...most odd and could almost be Italian. Not too stressed about this unless it is the precursor to something more major. Anyone else had anything similar?
So far so good, very happy with the purchase, not that I get to drive it much Big Cry
Post #151048 13th Nov 2012 12:45pm
Hunttheshunt
Just received the valves, not quite what I was expecting, no centre piece, do these just screw in, and can Kwik Fit do this??
Post #151058 13th Nov 2012 1:39pm
should look something like this,
Post #151085 13th Nov 2012 6:37pm
jfb1977
England 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
^^^What Stan said.
I don't know about Kwik Fit, but I know that a few tyre places claim to be experts in TPMS (mine was a nightmare on my S/C when I first got it)!
Not sure exactly where in the country you are, but Merityre have a few TPMS specialist branches who should know what they're doing.
Although in theory if you've bought the right valves the any tyre place can fit them, then you just inflate the tyres to the correct pressure and then they'll set themselves after a few miles.
Note 'in theory'... Wink Past (too many to list, but a few favs)...
2007 Porsche 997 C2S Coupe
2007 FFRR 4.2 S/C
2012 Jag XKR 5.0 S/C
2014 Merc SL500 AMG 4.7 V8 BiTurbo (remapped to 560BHP)
2011 FFRR 4.4 TDV8 Vogue SE - Overfinch Conversion
2012 Porsche Cayenne Turbo
2018 AMG C63S Estate
2015 Mercedes GLE63S
2017 Maserati Levante Diesel
2017 Audi A6 Avant 3.0 Black Edition
Post #151087 13th Nov 2012 6:43pm
jfb1977
Oh...and not sure it's much help but I borrowed my wife's 3 series the other day and when you put her heated rear screen on it totally destroys the radio signal.
I'm not sure how you'd fix that though... Confused Past (too many to list, but a few favs)...
2007 FFRR 4.2 S/C
Post #151089 13th Nov 2012 6:45pm
re the radio loss, if when you press MAX the heated rear window might be activated , and as the antenna is there there must be a short or bad connection... ... - .- -.
Post #151090 13th Nov 2012 6:50pm
Hunttheshunt
Thanks for the replies, mine do indeed look like Stans picture, but the actual central valve mechanism isn't there, if you look down the barrel so to speak there is just a hole and you can see through to the sensor underneath. Do the valves screw in, why would you take them out.....unless I'm missing something in both senses Shocked
Post #151093 13th Nov 2012 6:52pm
Hunttheshunt
Stan, thanks that makes sense both front and rear heated screens come on, I'll check the contacts on the rear.
Post #151094 13th Nov 2012 6:54pm
The centres just screw in - any tyre place can do that.
The fact they are missing means the valves are used - the centre was removed to deflate the tyre - but for £19 you knew that.......
Post #151095 13th Nov 2012 7:13pm
as said, the valve cores have been taken out... ... - .- -.
Post #151107 13th Nov 2012 8:12pm
Hunttheshunt
Thanks guys, was worried I'd bought a pair of lemons. They were described as coming off a brand new 2012 RR but obviously had been used just the once, so as I expected.
Post #151168 14th Nov 2012 9:12am
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
Same thing happened to me, but rather than risk the new modules not self-programming correctly, I unscrewed the new stems and put them on the original TPMS module. Small torx screw holds it together.
When it had happened to me before, even the dealer couldn't get them to program, so I wasn't prepared to take a chance.
Post #151220 14th Nov 2012 12:39pm
sleepezy
I'm changing my mind on TPMS at the moment - they always used to work for me and on the one occassion they were needed did warn me when I had a puncture well before it became a flat.
But now having to decide whether to either replace my 20" wheels (that have the TPMS) with new tyres or what were my replacement 19" that now 30k later also need new tyres with TPMS + tyres. Local fitter won't provide the TPMS (although will fit if I supply, without any guarantee they'll work) and I keep hearing differing stories over whether or not the blasted things will auto re-programme.
Even the local main dealer seems to be dithering in their opinion.
PS - from what I can gather the 2012 MY TPMS were smaller & squarer than the picture below (which is correct for earlier MY). NFI whether or not they are compatible... Same frequency... No guarnatee that this snippet of info is any more accuate that other stuff that's been said about TPMS either! Wink
Post #151227 14th Nov 2012 1:45pm
Hunttheshunt
All seems OK, Kwik Fit got their BIG jack out, new module and valve fitted and seems to sync just fine.
Thanks for your help!!
Post #151255 14th Nov 2012 6:22pm
They sync just fine - I swap wheels for winter - it just takes 5-10 mins of driving for them to get recognised.
Post #151271 14th Nov 2012 8:37pm
