![]() | Home > Technical (L322) > Range starting problem |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35882
sounds like the battery....if the original is over 3 years old then its time to get a new one." ... - .- -.
| Glm Member Since: 09 Dec 2011 Location: Manchester Posts: 105
Cheers stan thats what I am hoping as I have it on charge ! When I fitted charger it only registered 7.6 volts ? Current tdv8 range vogue 07 |
if that battery is still ok then that voltage should rise.. ... - .- -.
Just checked battery voltage is up to 11.6 but still nothing with key or lights Current tdv8 range vogue 07 |
Fully charged it should be around 14.6 volts |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
Are you charging it on the car? Have you disconnected any leads? You should leave it charging overnight to give it a full charge. Previously..
Still connected but battery showing 12.4 volts but still key won't turn and stilll no lights! Will disconnect in morning and leave on charge for the day whilst in work ! Current tdv8 range vogue 07 |
I think unless it's a battery conditioner type charger you can damaged the car by not disconnecting the battery.
| oliver9627 Member Since: 25 Oct 2012 Location: Chipping Norton Posts: 51
Glm
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
Oliver, have you checked the voltage while the engine was running ?? It is probably in the 14+ volt range i.e. the alternator is charging the battery, masking the imminent death of the battery.
