![]() | Home > Technical (L322) > Radiator cleaner |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8001
I used Holts Radflush a good few years ago. Cleaned out lots or crud from my mates Camel Trophy Disco....... Think it's in 2 parts now (Radflush, not my mates Disco !!)
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470
Yes I think it will. If you look down behind the rad you will see some smaller gauge hoses. These are the ones used for the gearbox cooling section. There is a little rad (trans cooler) at the bottom left. This is a coolant/trans fluid cooler. The new rad should enable the coolant in the smaller hoses to be cooler and help. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3989
Many thanks for the pic.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
No problem, this is good info for me as well. What happens after the flush, I think it is best to replace all the coolant and put new in ??? MY 2010 5.0 SC Galway green and sand interior!!
| jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147
After the flush, use NEW coolant. Jim
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
Most Transmission Specialists have a pressurised machine to properly flush the radiator & Oil Cooler plus pipes etc. Worth getting a quote for a proper flush. |
If you would live in 1st world countries yes, but here I wouldn't risk it. Hence my question. Getting coolant is not an issue here, getting flushing done is a different matter. Even getting radiator flush will be hard (might have to bring some back from Europe on the next trip. MY 2010 5.0 SC Galway green and sand interior!!
| oliver9627 Member Since: 25 Oct 2012 Location: Chipping Norton Posts: 51
Is there a certain Land Rover coolant that should be used for topping up the level, or will a general purpose anti-freeze be ok. |
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Depends on whats already in it really |
doh FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
I will get some in Holland when I am going over there in a few weeks time and send it back in the airfreight. The injector cleaner I can buy here is STP and seems to be the original stuff so I am not worried about that but haven't seen (nor looked for to be honest) radiator flush.
| All times are GMT |
