![]() | Home > Technical (L322) > Juddering and rough running on cold start |
Deasy Member Since: 26 Oct 2011 Location: Warwickshire Posts: 210 ![]() ![]() ![]() |
Hi all, i know there is a thread going about juddering, but i think this is differant.
Please can someone shed some light on this for me |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7934 ![]() ![]() ![]() |
Coil packs ? 2011 Range Rover Vogue SE 4.4 TDV8
Lol not got an egr,
How do I check the coil packs mark? |
Surely if the coil pack was faulty then if would be an issue on LPG aswell? |
I assume any wiring in the engine shouldn't be twisted together? Lol
That wiring is a right mess and bare wire showing too |
Yep I guessed that, I'm an electrician even though automotive is different to industrial and domestic, I hate people badging stuff, and thers no excuse for untidy half done jobs another than laziness |
not an expert on this, but i'm pretty sure you can swap the coil packs around and see if the fault moves with the pack or stays with the cylinder.....
Looks like there are a few wires there that have been tampered with and joined together with black tape |
@47p2
If the problem is only on petrol and not on LPG it is most likely the petrol fuel system. With the injector malfunction flaring up, I would say to start with the fuel injectors and not the coil packs.
The coil packs were a bit of a long shot, but can also show intermittent failure..........so if you've tried everything else.......
