![]() | Home > Technical (L322) > cabin is too hot |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
hi I may be wrong but have you tried to adjust the center face grill heater dial from red towards blue ?? i have mine on single red position otherwise it gets too warm |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 860 ![]() ![]() ![]() |
How warm is it outside? Do you see your electrical fan spinning? |
yawlboy Member Since: 02 Mar 2010 Location: RAK Posts: 53 ![]() ![]() ![]() |
thanks for the prompt responses,
There is an electrical fan in front of the radiator that should spin when AC is used. The exterior temperature is too low for the AC compressor to engage though, so maybe it's a final stage resistor thing. |
RREIRE Member Since: 22 Jan 2010 Location: Cork Posts: 83 ![]() ![]() ![]() |
Mine works fine. If you want to come and see. I am living in the same part of the world as you. |
Thanks RREIRE,
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
Mine is the same and my previous TD6 was not, it was VERY cool even at 22 degrees, this TDV8 is much warmer. It seems to stay hot for the first 30 mins, then starts to cool things down. Not a problem in the depths of winter but summer could be interesting.
I find that the system takes ages to adjust to the heat range set on the controls but does gets there eventually!
My PC is off limits...... ![]() |
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
You sure you do not need a re-gas of the system? You may have a leak somewhere. Java with Ivory 2006 4.2 Supercharged. 23.5k miles - NOW SOLD! |
We're in a no mans land in terms of outside temp at the mo and the ATC can get its knickers in a twist over what it should be doing.
ok now I'm getting worried - the car is fine one day and then roasting after 5 mins the next.
Are you using Johnston and Perrits in Cork? |
