![]() | Home > Technical (L322) > Won't start, help.!!! |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
It sounds like a classic battery fault. The cold weather will really show it up now. I had exactly the same problem. If there was a fault with the starter no amount of jumping would start it!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35769 ![]() ![]() |
this also sounds like anew battery is required.. ... - .- -.
If your car starts with a jump start there's nothing wrong with your starter.
Glm Member Since: 09 Dec 2011 Location: Manchester Posts: 105 ![]() ![]() ![]() |
Cheers for advice guys ! Not been on for a while but knew when needed help would come b4 getting recovery out to dealers ! Current tdv8 range vogue 07 |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 ![]() ![]() ![]() |
Ok hopefully as simples as that..! It's a shame I don't know how old the battery is though. Will keep u posted.
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3241 ![]() ![]() ![]() |
Make sure both the connections to the battery poles is tight. Even a little looseness can result in a bad connection. I once lost all power and it was a loose pole connection. |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Lol just got a Bosch S5 for £113 plus 5% cash back through quidco. Do they have eurocarparts there? They will deliver for £9.50 [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
A1GSS Member Since: 24 Dec 2010 Location: Saffron Walden, Essex Posts: 1973 ![]() ![]() |
Der. That light's there for a reason. Graham ____ Gone: 10MY L320 RR Sport HSE, Ipanema Sand Gone: 20MY Jaguar iPace HSE, Silicon Silver Gone: 17MY RR Evoque SE Tech, Loire Blue Gone: 08MY Discovery 3 XS, Stornoway Grey Gone: 07MY FFRR TDV8 Vogue, Stornoway Grey |
I know it's there for a reason, and I always wait for it to go off myself but just wondering if any harm can be done or if its an FYI type light that's telling u the glow plugs are heating up or whatever. |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16369 ![]() ![]() ![]() |
Lolo,
Halford s do them Lolo that's where I got mine 5 year warranty.hope you get sorted. Present :2008 TDV8 HSE
Ah thanks googsy ill call them tomo. |
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
bought a Bosch s5 110Ah 920cca job in halfords drogheda one week ago.it was a tasty 189 euro but the 5 year warranty helps and it starts the v8 instantly.Money well spent.they will test the battery before you leave the store and will fit it if you want.......
