![]() | Home > Technical (L322) > Key wont turn |
That's the weirdest problem I have seen sofar. Just try the battery dis-connection procedure (Wiki) and hold the two clamps together (while they are off) for at least 10 seconds to reset all faults. MY 2010 5.0 SC Galway green and sand interior!!
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35766 ![]() ![]() |
there can be a problem with the key mechanisium ....take the console off an inspect it , how to in the wiki i believe.. ... - .- -.
mrd1990 Member Since: 01 Jun 2011 Location: N. Wales Posts: 267 ![]() ![]() ![]() |
Have you tried both keys? |
Glm Member Since: 09 Dec 2011 Location: Manchester Posts: 105 ![]() ![]() ![]() |
Tried both keys !can only start it up a 2 nd time when I disconnect terminal and then it will turn over! Current tdv8 range vogue 07 |
Charmer Member Since: 28 Aug 2012 Location: Alton Posts: 156 ![]() ![]() ![]() |
Did you manage to resolve this?
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
When you first put the key in, can you hear any of the locks disengage? Even when I have had a flat battery it still let's me turn the key. Have you tried both keys? Previously..
Both keys would not turn.
Yes I changed the battery and no problem but when connected it up to computer it showed that the alternator was not charging he battery! Changed the alternator and have not had a problem! The battery has to have at lest 14 volts or the key wont engage ! I had to keep disconnecting battery every time I needed to start up until I changed the alternator ! Current tdv8 range vogue 07 |
Thanks.
That's good as the alternator was expensive ! Best getting battery fully charged and go from there ! Current tdv8 range vogue 07 |
Sorry didn't mention but it wouldn't let me turn the key before I charged the battery up only push it in ! Then nothing Current tdv8 range vogue 07 |
Good thread |
is this the bit you mean?
Just interested. |
