![]() | Home > Technical (L322) > (SOLVED) Who can identify this part on the transmission? |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 ![]() ![]() ![]() |
Hi gents,
Another (in focus this time please) photo needed further away so we can see where it is.
No other photo available at present im afraid. Thats the sump to the left of the photo. Seems to be the only part of the underneath thats stainless?, or atleast galvanised. MY2010 TDV8 Vogue Ipanema Sand
the filler plug is located more to the corner of the transmission according to RAVE. This mystery part is located more in line with the centre of the sump pan, half way along its length if this makes sense. MY2010 TDV8 Vogue Ipanema Sand
Is that the near side or off side? |
not sure ? dont have the rover with me to confirm. I'm not making it easy for you all! |
Needle in a haystack then |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
I agree with Brian, it looks like the end of the selector shaft
Thanks to brian and especially Phil for taking the time to post the drawings and photos. I'll get onto the case or replacing the seal. Will I need to drain some of the oil out when I remove the selector shaft ? Or can the seal be replaced with the rod in situe ?
I’m lucky in that I only work on transmissions that are sat on my workbench – in which case the seal is simple to access and replace! Working within the confines of the underside of a vehicle on a ramp – I’m not so sure how easy it would be. RAVE does describe the process though (albeit for the inhibitor switch end of the shaft). I think you’d have to do it with the shaft in-situ, otherwise you’d be looking at draining the fluid, removing the sump pan, removing the filter, removing the valve block, knocking out the roll pin that secures the rooster comb to the selector shaft, and then sliding the selector shaft over by 20mm or so until it clears the seal. Quite a big job (unless, of course, you were thinking of replacing the filter and fluid anyway).
I think ill leave it until its due an oil change then. It's only visibaly weeping and not dripping. Thanks for the info phill . |
