Home > Technical (L322) > (SOLVED) Who can identify this part on the transmission?
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Hi gents,
I've looked on RAVE and cannot identify this "screw" that is in the upper half of the transmission above the sump pan. It looks to be stainless steel and its weeping oil.
 MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #153922 27th Nov 2012 9:06pm
Another (in focus this time please) photo needed further away so we can see where it is.
On initial assessment it looks like the transmission filler plug (or a variant of it, or a 3rd party bodge - hence why it is leaking!) .
Post #153927 27th Nov 2012 9:27pm
woodchopper23
No other photo available at present im afraid. Thats the sump to the left of the photo. Seems to be the only part of the underneath thats stainless?, or atleast galvanised. MY2010 TDV8 Vogue Ipanema Sand
Post #153929 27th Nov 2012 9:29pm
woodchopper23
the filler plug is located more to the corner of the transmission according to RAVE. This mystery part is located more in line with the centre of the sump pan, half way along its length if this makes sense. MY2010 TDV8 Vogue Ipanema Sand
Post #153931 27th Nov 2012 9:35pm
Is that the near side or off side?
Post #153933 27th Nov 2012 9:42pm
woodchopper23
not sure ? dont have the rover with me to confirm. I'm not making it easy for you all! Question MY2010 TDV8 Vogue Ipanema Sand
Post #153935 27th Nov 2012 9:45pm
Needle in a haystack then Shocked
Post #153938 27th Nov 2012 9:50pm
Brian GOG
United Kingdom 2002 Range Rover HSE Td6 Epsom Green
I think its the end of the pivot shaft for the xyz switch. (if its the gearbox I'm thinking off). Not sure if they are any seals available for it though.
Post #154004 28th Nov 2012 12:28am
RRPhil
I agree with Brian, it looks like the end of the selector shaft
It’s the opposite end of the shaft from the splined end which drives the inhibitor switch, at the bottom of the photo below :
The leak will be from the 10x18x5 lip seal labelled /120 in the diagram below :
You can buy them from Land Rover – part number LR023293. Should cost less than £3.
Phil
Post #154013 28th Nov 2012 2:39am
woodchopper23
Thanks to brian and especially Phil for taking the time to post the drawings and photos. I'll get onto the case or replacing the seal. Will I need to drain some of the oil out when I remove the selector shaft ? Or can the seal be replaced with the rod in situe ?
Two thumbs up ! MY2010 TDV8 Vogue Ipanema Sand
Post #154017 28th Nov 2012 7:53am
RRPhil
I’m lucky in that I only work on transmissions that are sat on my workbench – in which case the seal is simple to access and replace! Working within the confines of the underside of a vehicle on a ramp – I’m not so sure how easy it would be. RAVE does describe the process though (albeit for the inhibitor switch end of the shaft). I think you’d have to do it with the shaft in-situ, otherwise you’d be looking at draining the fluid, removing the sump pan, removing the filter, removing the valve block, knocking out the roll pin that secures the rooster comb to the selector shaft, and then sliding the selector shaft over by 20mm or so until it clears the seal. Quite a big job (unless, of course, you were thinking of replacing the filter and fluid anyway).
The fluid level in the transmission with the engine running should be just about at the top of the sump i.e. at the face where it bolts on to the casing. With the engine off, the fluid level will be higher than this, but I’d be surprised if it went as high as the selector shaft level.
Phil
Post #154070 28th Nov 2012 1:22pm
woodchopper23
I think ill leave it until its due an oil change then. It's only visibaly weeping and not dripping. Thanks for the info phill . Thumbs Up MY2010 TDV8 Vogue Ipanema Sand
Post #154081 28th Nov 2012 2:51pm
