![]() | Home > Technical (L322) > timed climate not working |
| BOBCUSSEN Member Since: 25 Nov 2012 Location: DORDOGNE Posts: 296
hi folks, just thought i would mention another annoying fault with my NOV 2004 VOGUE. TD6
hi contraband, thanks for the reply. i will have a look at your othe reply. with regard to this other problem it is not really something i am too concerned over but it would be nice to know everything is working ok on the car should i ever want to us it.
hi again contraband, just looked at your other reply and is very interesting but i have a question, which i hope is not a stupid one. you mention that you took the optics out of the blue connector and put them in a straw to keep them straight. am i assuming that the blue connetor now has no wires inside it and is not put back into the unit.?
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700
Nokia is the Bluetooth module. There are 2 fibre optic cables go into each unit, an input and an output. If you take the connector out of the Nokia, then take both cables out of the connector (they are held in with a little clip). If you line up the ends perfectly the signal goes out of one cable and into the next, simulating passing through the Nokia. This bypasses the Nokia and if that was the only fault, the system will come back to life!
hi contraband , ok i think i get what your saying |
i looked on the wiki link and it has a decription of the denso system and on the pic of the screen, it shows that there is a light in the top right corner of the unit above the buttons? is that supposed to glow as i cant see anything shining out of it and cant remember if it ever did actually light up? |
hi contraband, my gps ,screen etc etc has just all come back on out the blue on its own, so any ideas or tests you can suggest to find out whats happening with the FBH. as mentioned before i can set the timer etc and that part seems to work and the light goes into its flashing mode to show its in the timing mode but nothing else happens after that. ie when the time is reached for it to start, nothing happens.
Wow... Question overload.. |
well i have heard a ticking noise in the past on several times and wondered it was but i have not tried to listen whilst selecting the heater to start? mainly as nothing happens when i try to start it? thats the problem, not knowing where to start looking. |
just to let everyone know who may have been watching this post, that the system is now up and running |
