|  | Home > Maintenance & Mods (L322) > Brake squeal |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | Buy a new set of pads from Dan at Duckworths   | ||
|  29th Nov 2012 9:20am |
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35885    | could be the actual pads, my wife had the same problem, changed the pads to another make and all was well.. ... - .- -.
|  29th Nov 2012 9:21am |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | Would you like to rephrase that Stan   | ||
|  29th Nov 2012 9:24am |
| benjj Member Since: 27 Feb 2012 Location: North Yorkshire Posts: 116      | Thanks chaps.
|  29th Nov 2012 9:34am |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048    | Send Dan a PM or call him | ||
|  29th Nov 2012 9:41am |
| benjj Member Since: 27 Feb 2012 Location: North Yorkshire Posts: 116      | Ta, will do. | ||
|  29th Nov 2012 9:42am |
| Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470      | I had he same problem with mine, even the extra rubbing noise when turning.  Replaced the caliper and all was good.  Maybe your caliper has started to stick a bit?????  I got a new one off the bay for £45 so might be worth a try. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
|  29th Nov 2012 2:23pm |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1564    | Another vote for the pads.  Some pads and disc combos just squeal with the type of braking the driver does.     I used to get squeal from the rears a lot ... i figured it was cause I did a lot of long gentle braking with the horse trailer attached.
|  29th Nov 2012 3:36pm |
| Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700    | You can never use enough copper grease. Slap it all over, well, the back of the pads I mean. It's defo the front? What happens if you put the handbrake on a bit, does the noise go? Previously..
|  29th Nov 2012 3:52pm |
| northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8790      | When I just did my rear pads one was starting to squeak a bit, picked up some copper grease and the chappie in ECP said that PAGID now did their own non metallic compound which was better at stopping squeal. only cost a couple of squids for a small tube and seems to have done the trick, along with the new pads that is. There is nothing that can't be fixed with a hammer😜😜
|  29th Nov 2012 4:49pm |
| Posting Rules
