Home > Technical (L322) > Diagnostic tools
tony1kenobee
England 2003 Range Rover Autobiography 4.4 V8 Zambezi Silver
Diagnostic tools
Hi all,just had an engine light come and am keen to know what it is? I'm looking for a reader to tell me the code which identifies the problem.not looking to spend too much but want a reliable one,any ideas or pointers would be great.its my first RR and not keen on spending 50 bucks or quid on someone else telling me what's wrong .regards in advance
Tony
Post #154659 1st Dec 2012 1:46am
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
IID TOOL Thumbs Up
Post #154661 1st Dec 2012 8:22am
IID Tool Thumbs Up +1 ... - .- -.
Post #154664 1st Dec 2012 9:49am
ebajema
Hi Tony, even if you go to someone with a diagnostic tool that doesn't mean they can tell you what is wrong. The codes are limited and you still need a smart and/or experienced mechanic to use the fault code info and usually other information to find out what is wrong.
On this forum it is clear to me at least that IID is the preferred one, it seems to work very well and the manufacturer and his team are doing a lot to support their product (just trawl around here and you will see what I mean).
I use the Faultmate, which is by no means faultless !!, a very elaborate tool similar to the functionality of the T4 testbook of Landrover. It has more functionality than the IID but that doesn't mean it can help you in this situation. I would probably have chosen the IID as well, if I had known about its existence at the time as I believe it is substantially cheaper. Plus I believe Steve and his team are developing it further, hopefully for IID users to the same level as the Faultmate with less "issues".
If you want to tinker with all the car settings (and there are a LOT of them) and re-flash ECUs, then you are limited to the Faultmate (ECU reflashing is not an "easy" thing by the way and not without risk). If you want to do diagnostics and (limited ??) setting changes then IID will work.
My suggestion is, have a good look at the specs of each of them with your preferences/requirements in the back of your mind. MY 2010 5.0 SC Galway green and sand interior!!
Post #154665 1st Dec 2012 10:05am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
IIDTool Thumbs Up +2
Post #154999 3rd Dec 2012 4:30am
oliver9627
United Kingdom 2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Where do you buy an IID Tool from and what do they cost? Gone:
Golf GT TDI 150- Still got.
BMW 325TD
Range Rover Classic
Defender 90
Post #155001 3rd Dec 2012 8:15am
the IIDTool is distributed by britparts to dealers across the country.....there is no set price as the dealers sell at different prices ...its best to google and compare prices or read the IIDTool threads here on the forum as members post how much they paid and where they got it from... ... - .- -.
Post #155011 3rd Dec 2012 9:19am
The Brains Trust
Australia 2003 Range Rover HSE Td6 Adriatic Blue
IID Tool + 3 Thumbs Up
Best price I found was on flea bay.
Post #155717 6th Dec 2012 12:08pm
