![]() | Home > Technical (L322) > Perm jump start connector |
With winter already saying its on its way and already having performed a few jump starts for people and needed one myself after being an idiot im thinking of getting something like this rigged up on the FF
After working on the car so much and being in the arches for the front sump guard and wheel swaps i want to avoid that area as even with covers its mucky and slimey as hell |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3983 ![]() ![]() ![]() |
The largest cable at the back of the car is 16mm˛ and rated and fused at 100A, it serves the rear fuse board.
Well thats my idea fannyed on! |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 8111 ![]() ![]() ![]() |
I've got these on all 3 of our cars (and a boat)
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
What about a James Bond style lift up number plate? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
rathbranV8 Member Since: 23 Jan 2011 Location: meath Posts: 283 ![]() ![]() ![]() |
was reading LRO the other day and saw these connectors,was having similar thoughts but placement is testing me.Behind the front grille seems about the easiest place or if you wanted to go to the trouble or long cables to the rear hitch and towing electrics could be more subtle,but the routing is an issue,still drinking lots of tea thinking bout it... |
Im thinking RAC/AA style and on the front bumper, the middle lip below the number plate.
sounds like a plan.I want them for ease of charging,saves having to pop the bonnet when i stick the ctek on in the garage,more for convenience than anything but will come in handy as jumping points as well.will drink more tea and have a longer look at the bumper today |
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Don't drive or knock into anything, or hope someone doesn't reverse into the front of your car while in the supermarket. You can't beat a big live exposed knob ![]() And mind out if you go off road. |
I go off road quite a bit but it would be covered and it would have to be a decent smash to split the connector so much that the two small pieces of exposed metal touched each other. A large inline fuse would probably do, say 100amp? Cheap enough to fit |
Could you do anything with the grill? Make a flap of some sort? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Maybe you need a drop of whiskey in that tea |
