Home > In Car Electronics (L322) > Blinking odometer with indicators! |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3955 |
It's not the battery or alternator.
5th Dec 2012 9:24pm |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
Both lights are lit, will have a go at removing/refitting them. So you think these are two unconnected problems? Where's a good place to start looking for my dodgy earth? None of the actual vehicle lights (head/tail etc) dim with the indicators nor do the speedo backlighting just the pixel LCD backlight 2003 Vogue 4.4 V8 Java Black |
5th Dec 2012 10:03pm |
Have you got canbus error free leds in the numberplate lights? |
5th Dec 2012 10:30pm |
Lolo Member Since: 16 Feb 2012 Location: Leinster Posts: 608 |
I don't know about the odometer problem, but for all external lights u can't simply put any led light in, they have to be canbus error free LEDs or else ur gonna get the warning lights up on the dash even tho the lights are working. This is cause LEDs use less power than regular bulbs so basically when u put an led instead the car doesn't recognize it.u can get them on the bay for pennies.just search for error free LEDs or canbus LEDs etc |
5th Dec 2012 10:45pm |
Yes, had no errors since they were installed months ago? 2003 Vogue 4.4 V8 Java Black |
5th Dec 2012 10:46pm |
EVOeng Member Since: 14 Sep 2011 Location: Surrey Posts: 221 |
Tuts, a friend had the same problem and was told that it is normal for the dash lights to pulse/dim slightly. |
6th Dec 2012 6:50pm |
as long as nothing's about to fail I can handle a little 'normal' quirk! Cheers! 2003 Vogue 4.4 V8 Java Black |
6th Dec 2012 8:14pm |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1255 |
The light control module has a bus-bar design that supplies all of the power transistors powering the lights with the positive supply voltage.
6th Dec 2012 11:31pm |
With regards to the rear number plate LEDs, really strange as the car was initially happy with the LEDs with no error messages at all for about 5 months, this week it seems to not like them anymore? Changed back to bulbs and no more error messages? Bizarre !?!? 2003 Vogue 4.4 V8 Java Black |
7th Dec 2012 6:28pm |
