Home > Technical (L322) > FBH Remote Pairing
Olders
United Kingdom 2016 Range Rover Autobiography SDV8 Loire Blue
FBH Remote Pairing
My FBH remote (T90) wasn't pairing, even after replacing the batteries.
After searching the forum and reading the various posts on this, I tried the procedure in the Wiki ("pull" fuse 59, wait 10 secs, replace fuse and within 5 secs press "off" button on remote for 2 secs). No joy.
Eventually, I tried the same procedure but pulling the power cable out of the Webasto Telestart T90 receiver unit directly, instead of Fuse 59. Hey presto! Works like a charm! No more frosty windows, frozen locks and freezing starts to your journey!
FYI, for those that don't know, the receiver unit is attached to the back of the rear fuse panel (which you will have to remove - three 8mm hex bolts - very easy), which can be found behind the panel on the right hand side of the luggage compartment.
Just thought that this might be worth adding to the Wiki on this ...... in case others encounter the same problem with the 'Fuse 59' procedure. -----------------------------------------------
2016MY FFRR 4.4 SDV8 Autobiography Loire Blue
2007MY FFRR 3.6 TDV8 Vogue SE Tonga Green
Post #106952 12th Feb 2012 5:45pm
Thumbs Up Good to know , maybe stan might add it to the Wiki ...
Post #106954 12th Feb 2012 5:51pm
le25dse
Norway 2014 Range Rover Vogue TDV6 Loire Blue
It sounds like your receiver unit is attached to the wrong side of the fuse, so it is always live.
Post #106971 12th Feb 2012 7:39pm
taskam
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
I got a remote from the bay, but when I took fuse panel off to locate the FBH receiver, I only found a box for the PDC. Is there another location for the receiver for late 2006 models?
Post #155963 7th Dec 2012 1:36pm
My old one a 06 TD6 paired fine by removing the fuse but my new one an 08 Supercharged you must remove the power lead to the receiver so I suspect something happened to the wiring after the introduction of Terrain Response . 2008 MY Supercharged
Post #156010 7th Dec 2012 6:19pm
taskam
Yea, tried the fuse 59 method and no luck. Should have said its a Vogue SE TDV8. Looked in both sides, plenty of RF and other module but I haven't seen anything with Webasto label.
Thanks.
Post #156018 7th Dec 2012 6:53pm
JW911
axle wrote:
... after the introduction of Terrine Response .
This is a new device on later models which also heats your soup. Wink 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #156024 7th Dec 2012 7:25pm
[quote="JW911"]
This is a new device on later models which also heats your soup. Wink[/quote
Rolling with laughter Rolling with laughter
just saw that , but then I am quite hungry right now . 2008 MY Supercharged
Post #156037 7th Dec 2012 8:29pm
Martin
Site Admin
Laughing
Post #156038 7th Dec 2012 8:30pm
stu
just make sure that your battery is in good condition if you are using the FBH!! half an hour is an long time and the dead mans click is very depressing!! Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #156226 9th Dec 2012 8:44am
