Home > In Car Electronics (L322) > Phone disconected-solved
mjdronfield
54 pin connector unplugged from the phone control unit. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #156344 9th Dec 2012 8:09pm
Lol.. I did say check all the connections!! Glad it was an easy fix. Previously..
Post #156348 9th Dec 2012 8:15pm
mjdronfield
I don't think he realised he even needed it, so checking wouldn't have helped. Wouldn't have been visible in his boot.
Looks like his TCU is mounted the other way up, so the 54 pin plug is at the bottom. Must have not been plugged in securely, and finally got pulled out whilst he was swapping the nav units over.
In the 7th post, he mentioned it wasn't used............
Got there in the end 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #156353 9th Dec 2012 8:19pm
You did well there.. Great with the tech drawings, pictures etc... Thumbs Up Previously..
Post #156354 9th Dec 2012 8:22pm
Norway
Norway 2003 Range Rover Vogue Td6 Adriatic Blue
The problem where only a lose switch. Since it was out off viewing range i did not know about it. -03V td6
-72 Cadillac Coupe DeVille 7,7liter.
Post #156455 10th Dec 2012 2:05pm
