Home > Maintenance & Mods (L322) > Check spare tyre pressure
crookedm
2007 Range Rover Vogue SE TDV8 Java Black
This showed up this morning, I take I do just that then!
Could the cold affect this ?
Post #156940 12th Dec 2012 3:15pm
yes and yes... Thumbs Up ... - .- -.
Post #156944 12th Dec 2012 3:26pm
crookedm
I'm amazed everyday how advanced this thing is! 5 years old and the tech in it is better than some more recent vehicles. Ill be checking the tyre tonight. I didn't expect 2 bongs this morning (not that type) to warn me. Temperature and spare tyre. Just fantastic.
However! When you pump the tyre up and I keeps telling you to check the spare its bloody annoying. How does the car know its spare tyre is below pressure?
Post #156947 12th Dec 2012 3:30pm
Andy_J
Scotland 2007 Range Rover Vogue SE TDV8 Java Black
You need to go for a drive to give the system time to register you have pumped up the spare tyre. That is assuming that the cold has not killed off the battery in the tyre sensor in your spare. Make sure you have got the tyre pumped up to the maximum recomended pressure. 56 TDV8 Vogue SE
9 Freelanders, 2x 2002 TD4ES, 2001 TD4, 2002 1.8GS, 2000 XEDI, 2x 2000 1.8ES, 2004 1.8 & 2000 1.8 GS (rolled)
91 Lotus Carlton (sold)
90 Lotus Elan (BRG)
Post #157042 12th Dec 2012 9:15pm
crookedm
Oh right ok, I did put the engine on without driving it before I posted this so I will be driving it tomorrow morning. How easy is it to replace the battery in the sensor and also how do the sensors tell the car it's tyre is low I don't understand it at all!
Post #157057 12th Dec 2012 9:45pm
T24RES
Inflate as per fully laden on the tyre sticker on the B pillar. Otherwise it can still bong if set to regular pressure Thumbs Up
Post #157071 12th Dec 2012 10:28pm
crookedm
Off to my local garage to use their air pumps got to be better than the electric crap one I've got!
Post #157074 12th Dec 2012 10:36pm
Andy_J
The battery in the sensor is not designed to be replaced. The sensor is a sealed unit with some kind of resin or glue holding all the parts in place.
The sensor is sat on the back of the tyre valve and has some kind of pressure switch inside it. When you drive the vehicle the car sends a signal to each of the tyre sensors in turn from antena fixed inside the wheel arches. Each sensor then responds as appropriate. 56 TDV8 Vogue SE
90 Lotus Elan (BRG)
Post #157078 12th Dec 2012 10:48pm
crookedm
Full marks!
http://www.fullfatrr.com/forum/topic1321.h...e+pressure
Thanks Andy all is clear! Clever stuff if not a little overkill!
Put tyre upto 42 drove for about an hour today. Bloody thing still showing up as check spare tyre. Very annoying. TPM Censored me off!
Post #157080 12th Dec 2012 11:05pm
