![]() | Home > Maintenance & Mods (L322) > Check spare tyre pressure |
crookedm Member Since: 23 Sep 2012 Location: Heswall Posts: 698 ![]() ![]() |
This showed up this morning, I take I do just that then!
yes and yes... |
Andy_J Member Since: 14 Nov 2011 Location: Muir of Ord Posts: 479 ![]() ![]() ![]() |
You need to go for a drive to give the system time to register you have pumped up the spare tyre. That is assuming that the cold has not killed off the battery in the tyre sensor in your spare. Make sure you have got the tyre pumped up to the maximum recomended pressure. 56 TDV8 Vogue SE
Oh right ok, I did put the engine on without driving it before I posted this so I will be driving it tomorrow morning. How easy is it to replace the battery in the sensor and also how do the sensors tell the car it's tyre is low I don't understand it at all! |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
Inflate as per fully laden on the tyre sticker on the B pillar. Otherwise it can still bong if set to regular pressure |
The battery in the sensor is not designed to be replaced. The sensor is a sealed unit with some kind of resin or glue holding all the parts in place.
Full marks! http://www.fullfatrr.com/forum/topic1321.h...e+pressure Thanks Andy all is clear! Clever stuff if not a little overkill! Put tyre upto 42 drove for about an hour today. Bloody thing still showing up as check spare tyre. Very annoying. TPM ![]() |
