![]() | Home > Maintenance & Mods (L322) > Replacing the high beam+fog beam for 2004 Range Rover |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 ![]() ![]() ![]() |
I don't doubt that you're right Stan, but I've not seen that option in Navcoder or RSW - has IID got it? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35769 ![]() ![]() |
there is a drl main beam setting with different percentage power options , so in theory i suppose the GAP chaps could work something out...its not really been explored as there hasnt been a need for it.. ... - .- -.
That's all NavCoder has - you can change the %age of power for the DRLs - not the actual night time headlamps. |
the easiest way would be to use the 10volt feed to trigger a relay with the full 12 volt power coming directly from the battery [what u said |
i do remember Daveo doing something like this and it working ok...
alahmed Member Since: 03 Jun 2012 Location: Jeddah Posts: 62 ![]() ![]() ![]() |
thank you Simes and thank you Stan for participating in this issue.
You will be wasting a lot of power messing about with resistors. Get Navcoder or IID tool - anything - and then just turn off the warnings after wiring in the new stuff properly with a relay. |
