Home > Maintenance & Mods (L322) > TD6 - front pad fitment and wear indicator
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Need to order some front pads for my 2003 TD6 and will get new wear indicator too, are all TD6 front pads the same size? (Read the post on here with 2 different size pads on a guys TDV8). Also, how many wear indicators will I need for the front in total?
And going to use ECP as few discount codes floating around, are Pagid fairly good?
Post #159220 22nd Dec 2012 3:43pm
andyboy
Wales 2004 Range Rover Vogue Td6 Java Black
One wear indicator per axle, nearside front and offside rear not sure about the pad sizes though. when i ordered mine i gave my reg and the ones i had were right. Hope that helps. gone fishin'
Post #159230 22nd Dec 2012 5:12pm
There are two different pads for your TD6, make sure you order the correct ones
Post #159235 22nd Dec 2012 6:04pm
mrblonde
Cheers guys
47p2, how would I tell what size pads I need?
Post #159240 22nd Dec 2012 6:37pm
Easiest way is to take an old one out, that way you can't get it wrong Thumbs Up
Post #159244 22nd Dec 2012 6:42pm
mrblonde
Knew you was gonna say that...... Sad
Post #159246 22nd Dec 2012 6:44pm
It is the easies foolproof way Thumbs Up
Post #159248 22nd Dec 2012 6:45pm
mrblonde
Have bit the bullet and put my faith in ECP's 'enter your reg' system and ordered front Pagid pads @£33, plus front wear sensor (just in case) and copper grease and brake cleaner.
My MOT advisory also mention a front brake pipe deterioration, best to get this from LR themselves?
Cheers
Post #160047 26th Dec 2012 3:39pm
Flexi pipes from LR, metal pipes have the garage make them from Kunifer
Post #160048 26th Dec 2012 3:43pm
SteveMFr
Site Sponsor
Actually there is only one pad for the 2002-05 TD6 - there is another pad for the 2006 TD6, tho.
Have your parts guy show you a diagram of the pads. Yours have the T-shaped tabs at the ends while the 2006 pads (which are the same in the D3 and RRS TDV6) have stright tabs at both ends.
And from what I gathered, one person f@cked up and wrote very confusing descriptions in the parts catalog and everyone else copied the catalog description off this idiot. So there are lots of wrong pads being shipped out. Ask me how I know. Rolling Eyes
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #160104 26th Dec 2012 11:31pm
Coz you were the guy Laughing Laughing
Post #160107 26th Dec 2012 11:35pm
I did wonder because I ordered some pads from Duckworths and he didn't ask which ones.
They fitted btw.
Post #160110 27th Dec 2012 12:03am
SteveMFr
Site Sponsor
...on the receiving end, yup. Twice. Because I'd forgotten over the life span of a set of pads. Big Cry
Actually, all L322 calipers (both diesel and petrol) are the same from 02-04 and poss into 05 - I'd have to check on the petrol, the TD6 calipers didn't change until 06.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #160113 27th Dec 2012 9:08am
I had new pads sent to me from Dan and they were the wrong ones Shocked
Post #160130 27th Dec 2012 11:06am
I guess I just got lucky.
Post #160148 27th Dec 2012 12:31pm
