![]() | Home > Maintenance & Mods (L322) > TD6 - front pad fitment and wear indicator |
| andyboy Member Since: 24 Aug 2010 Location: south wales Posts: 540
One wear indicator per axle, nearside front and offside rear not sure about the pad sizes though. when i ordered mine i gave my reg and the ones i had were right. Hope that helps. gone fishin' |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
There are two different pads for your TD6, make sure you order the correct ones |
| mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766
Cheers guys
Easiest way is to take an old one out, that way you can't get it wrong |
Knew you was gonna say that...... |
It is the easies foolproof way |
Have bit the bullet and put my faith in ECP's 'enter your reg' system and ordered front Pagid pads @£33, plus front wear sensor (just in case) and copper grease and brake cleaner.
Flexi pipes from LR, metal pipes have the garage make them from Kunifer |
| SteveMFr Site Sponsor Member Since: 22 Nov 2009 Location: Strasbourg, France Posts: 1641 |
Actually there is only one pad for the 2002-05 TD6 - there is another pad for the 2006 TD6, tho.
| JOKER Member Since: 11 Sep 2008 Location: Sconnie Botland Posts: 15876
Coz you were the guy |
| KurtVerbose Member Since: 08 Aug 2010 Location: Les Arses Posts: 5848
I did wonder because I ordered some pads from Duckworths and he didn't ask which ones.
...on the receiving end, yup. Twice. Because I'd forgotten over the life span of a set of pads. Actually, all L322 calipers (both diesel and petrol) are the same from 02-04 and poss into 05 - I'd have to check on the petrol, the TD6 calipers didn't change until 06.
RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
I had new pads sent to me from Dan and they were the wrong ones |
I guess I just got lucky. |
| All times are GMT |
