Home > In Car Electronics (L322) > No GLS listed on Head Unit
Paulhh
Scotland 2002 Range Rover Vogue 4.4 V8 Epsom Green
Hi
Just bought my first Range Rover, what a fantastic vehicle.
Having a problem with the Head Unit, it doesn't see the CD's in the changer and also doesn't list the Sat Nav in the Menu or the CD unit. I have found that there isn't any power at the moment to the Nav Unit in the boot, would this then cause it not to be listed?
OR, would both these issues point to the Head Unit, radio works by the way so at least some sound Smile
Cheer for your help
Paul
Post #159465 23rd Dec 2012 10:08am
mjdronfield
Hi Paul.
The screen in the front is just that, a screen. It is controlled by and connected to everything in the boot. The units will not be appearing on the screen as they are not identifying themselves on the ibus. Your issue is definately in the boot, and having no power to sat nav unit will cause issues, as the units tend to "daisy chain" through each other.
Check the fuses for the nav and double check all the plugs on the units in the boot.
Have a look for water ingress / dampness near the units, and on the boot floor (near the spare wheel) as this can be a common issue, which tends to damage the electronics.........
In the first instance, I'd investigate the power to the nav unit, and go from there.........you will need those standard radio removal tools to get it out, or you can use a coat hanger or something if needs be.
EDIT: Just had a look on RAVE, Fuse 40 in the glove box is for the CD changer and should be 5 amp, can't see one specifically for the sat nav, but as the radio is working, I'd imagine power is fine to the boot area......
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #159470 23rd Dec 2012 10:37am
Paulhh
Thanks for that. The CD is getting power as the disc cartridge does eject and appears
to work, just no discs read at unit. But as you say the Head Unit just monitors then the
CD unit must be goosed.
The Nav unit (DVD) in the back has no lights and won't eject so I'll look at the power in
that area. Must be power at the radio so maybe a loose connection in the boot.
Post #159492 23rd Dec 2012 12:03pm
Paulhh
The Nav Unit isn't the DVD, oops, its the CD version. I also found a matchstick jammed in the side of the blue connector so I would guess somebody previously has had a problem and got round it by jamming the plug into the Nav unit.
Still to measure the voltage though as it has the smallest holes, I'll need to find some wire to poke into the holes to enable me to read the voltage.
Fuse No 40 does do the CD changer unit but that already has power, so must be the head reading the discs not working.
Post #159502 23rd Dec 2012 12:37pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
If the nav unit is not working or unplugged the display looks completly different, can you take a pic of the display? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159503 23rd Dec 2012 12:38pm
Paulhh
Brilliant help on here.
Knowing that the display was different when the Nav Unit wasn't working was exactly what I needed. I didn't take the photo but I did jiggle the blue plug which then put power onto the unit.
Once the power was there then the Head Unit display changed to give me the On road GPS and Off road.
Just left with the CD changer not reading CD's
Thanks
Post #159504 23rd Dec 2012 12:45pm
JohnnyDangerous
CD changer will be the laser !!! I have one im selling after xmas with new cartridge as im going intravee and Ipod, all working perfect. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159506 23rd Dec 2012 1:03pm
Paulhh
Sounds like I need to buy that from you.
Post #159507 23rd Dec 2012 1:04pm
JohnnyDangerous
Not sure how much laser replacement is, might be worth checking that first, they normally seem to be about £200 on e.bay, as long as I can cover the cost of the intravee I would be happy (£150) Try these guys first for a quote
http://www.revtronic.com/index.php?option=...Itemid=194 One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159509 23rd Dec 2012 1:10pm
Paulhh
Thanks Buddy, I'll give them a call, maybe they will take my unit and re-furb it.
Post #159510 23rd Dec 2012 1:12pm
JohnnyDangerous
The laser itself is prob cheap its the fitting, does the cd changer try and load a disc or does it have a stuck disc in it. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159511 23rd Dec 2012 1:15pm
Paulhh
It seems to go through it's normal load, I've put in 3 discs in different positions in the cartridge but on the Head Unit it still says no discs loaded.
Post #159521 23rd Dec 2012 2:07pm
Paulhh
Just another quick question. When I was taking the Nav uit out I found an aerial lead lying loose. It looks like one that would normally plug into an ordinary head unit so not sure where it would go as it's lying in the boot. My radio does pick up the radio stations without this connected.
Post #159532 23rd Dec 2012 2:27pm
JohnnyDangerous
Where are you? might be worth trying another members cartridge in there to see if thats the problem. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #159535 23rd Dec 2012 2:32pm
Paulhh
I'm in Carrbridge up in the highlands
Post #159537 23rd Dec 2012 2:34pm
