![]() | Home > In Car Electronics (L322) > No GLS listed on Head Unit |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
Hi Paul.
Paulhh Member Since: 23 Dec 2012 Location: Carrbridge Posts: 143 ![]() ![]() ![]() |
Thanks for that. The CD is getting power as the disc cartridge does eject and appears
The Nav Unit isn't the DVD, oops, its the CD version. I also found a matchstick jammed in the side of the blue connector so I would guess somebody previously has had a problem and got round it by jamming the plug into the Nav unit.
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
If the nav unit is not working or unplugged the display looks completly different, can you take a pic of the display? One day your life will flash before your eyes......................................make sure yours is worth watching!
Brilliant help on here.
CD changer will be the laser !!! I have one im selling after xmas with new cartridge as im going intravee and Ipod, all working perfect. One day your life will flash before your eyes......................................make sure yours is worth watching!
Sounds like I need to buy that from you. |
Not sure how much laser replacement is, might be worth checking that first, they normally seem to be about £200 on e.bay, as long as I can cover the cost of the intravee I would be happy (£150) Try these guys first for a quote
Thanks Buddy, I'll give them a call, maybe they will take my unit and re-furb it. |
The laser itself is prob cheap its the fitting, does the cd changer try and load a disc or does it have a stuck disc in it. One day your life will flash before your eyes......................................make sure yours is worth watching!
It seems to go through it's normal load, I've put in 3 discs in different positions in the cartridge but on the Head Unit it still says no discs loaded. |
Just another quick question. When I was taking the Nav uit out I found an aerial lead lying loose. It looks like one that would normally plug into an ordinary head unit so not sure where it would go as it's lying in the boot. My radio does pick up the radio stations without this connected. |
Where are you? might be worth trying another members cartridge in there to see if thats the problem. One day your life will flash before your eyes......................................make sure yours is worth watching! ![]() |
I'm in Carrbridge up in the highlands |
