![]() | Home > In Car Electronics (L322) > PC Feed - remove TV? |
| DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027
Hi guys,
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7980
Would it not be easier to leave the TV unit in and feed the PC signal in as an AUX ?
Is there an AUX video input on a 2006 touch screen that doesn't involve removing the dash? Land Rover Addict
| Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700
Only if you have RSE |
Can it not be added, like an additional loom bit or such like, same as the BMW system in mine ?
| kingpleb Member Since: 07 Jun 2011 Location: Maybe here. Maybe there, I get everywhere! Posts: 8455
Yeah the MOST system takes a fibre feed from the TV tuner and sends it to the AMP and screen IIRC and in simple terms.
| wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 |
The picture feed from the tv or RSE to the touch screen is a coax lead .
| Ajay(UK) Member Since: 02 Mar 2010 Location: Arundel, W. Sussex Posts: 608
Couldn't he put an RCA switching box between the TV out and the connection to the rear of the monitor? Then leaving the TV tuner in place so as not to "upset" the ICE system select TV from the touch screen and switch the feed between TV and PC using the switching box????? |
