![]() | Home > Technical (L322) > Advice on a groan |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
One of the rear calipers sticking, any fitter can remove it and free off and lubricate to get you home then about £69 from eurocar parts. One day your life will flash before your eyes......................................make sure yours is worth watching!
benjj Member Since: 27 Feb 2012 Location: North Yorkshire Posts: 116 ![]() ![]() ![]() |
Do you really think it could be a caliper sticking?
When my front caliper stuck it was horrendous and the more you drive the hotter it gets and sticks more, easy to check as one will be far hotter than the other, squirt some water on them when it does it.
Missed my main chance to check as have just been out for 20 mile trip. That said after 15 mins stationary - have 3 disks that are more or less cold, one still with some residual heat (nsr) - guess you could be right, thanks! Will check it out tomorrow when light.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8768 ![]() ![]() ![]() |
mine is doing exactly the same but with a squeal not a groan, get a cup of water and chuck a bit on each disc after a run, the stuck one will be hissing.
