![]() | Home > General > Fueling up |
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
Must be either the pump or how your using it.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6383 ![]() ![]() |
This could be the same issue I have. I've not found a diesel nozzle yet that goes all the way in, I think it's due to the anti-petrol nozzle guard in the diesel models.
Dexter Member Since: 12 Jul 2008 Location: Up North Posts: 47 ![]() ![]() ![]() |
car is MY08 I'll mention this to them thanks - but I'll give it a while so I can enjoy the car a bit before she has to go in. |
I'd be interested to hear how you go on in a couple of weeks, will you do a post? |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
I've never had any problems filling mine up, (2003 petrol)
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
I've only had this a couple of times. I found rotating the pump nozzle 10 to 15 degrees cured it.
dantheman Member Since: 02 Feb 2009 Location: North: Lancs Posts: 477 ![]() ![]() |
I get cramp in my hand, oh, and my wallet hurts... |
One of the down side of living in the Booniesis that we pay about £37.50 for a liter of fuel , one of the good sides is that most of the independent garages still use the trigger locks so you can lean on the pump and smoke a tab . |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 805 ![]() ![]() ![]() |
![]() ![]() ![]() That's only £3000 for a FFRR tank-full. Perhaps I was missing the irony...... ![]() The TDV8 anti-misfuel device prevents the diesel nozzle from going all the way in. As for 'clicking-off' all the time, turn the nozzle though 180deg and you'll find it fills perfectly. Often works best if you are on the wrong side of the pump (quiet lane) and the fuel hoses are connected high. Saves waiting for a vacant pump and it looks more like a F1 pit-stop. ![]() ![]() |
Not irony just p***d off at paying nearly 80% tax on fuel and getting sod all back for it. 2008 MY Supercharged
+ 1 |
RRVSE Member Since: 18 Apr 2009 Location: Bury Posts: 597 ![]() ![]() ![]() |
I used to always get my fuel from the big brands like Esso or Shell, but now use tesco and have no problem with their pumps. They're also usually cheaper and I feel better getting clubcard points! (only 10s of pounds but better than nothing!). Steve
Kilovolt Member Since: 07 Feb 2010 Location: Derbyshire Posts: 104 ![]() ![]() ![]() |
On 2010 diesel models there is an anti petrol filling neck and flappy device inside the throat of the filler. Pain in the a**e as it slows the filling process (with diesel hopefully |
