![]() | Home > Technical (L322) > One key can't turn ignition on |
| Ibartsimp Member Since: 25 Dec 2012 Location: Bordeaux, France Posts: 197
Hi,
| duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217
new fob from land rover can only be ordered with a VIN, so if the key did come from LR it will be correct to your vehicle, just sounds like it needs programming in at a dealer. You can paypal direct using - www.paypal.me/duckworthparts
Thanks to you both, that's perfectly clear. It looks like the key wasn't made after the VIN, meaning the transponder (that I had spotted in the key) isn't operating.
| ebajema Member Since: 24 Mar 2011 Location: New Plymouth Posts: 4782
I may not have been clear. When you get the correct key, it still needs to be "programmed" to the car as Dan said. I have done it for my three keys (two existing and a new one) using the Faultmate. Basically you are telling the car that those keys are accepted as useable keys.
I think I had understood correctly. Unless the transponder is factory programmed the car won't start.
| nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3988
If I'm not mistaken you could always change the working transponder from the old key to the new key. Simple job. |
done that already |
Making the doors open and close you can do without the "computers" like the Testbook and Faultmate and the likes. That is a simple procedure you can find on the site here by doing a search. Make sure you do all the keys.
ok, thanks for these explanations so adding a new key (with new transponder) always requires an intervention on the car (faultmate, t4 or whatever) |
| 47p2 Member Since: 05 Oct 2010 Location: Gone Beyond, Subaru Posts: 8048
The transponder should work without going through 'the procedure' of syncing the key. When you purchase a new key it will start the vehicle without going through 'the procedure'
When I got my new key from the dealer, I had to take all three keys and "tell" the car that these are not the active keys using the Faultmate. It did not work on the ignition/steering lock at all until I did the key learning procedure.
Ok, just to make sure that I understand, can someone post the step by step process & sources to get from 0 to a complete working key (excluding remote part if needed since it's been widely covered).
