Home > Technical (L322) > MY08 Key fob buttons not operating lock/unlock/boot---sorted
T24RES
Been out this morning all was well. Returned home to experience the fob won't lock the car on the button. Second fob won't work either. Search revealed syncing on earlier model keys. Doesn't appear to work with the MY08. The key works in all manual modes (ie, in door lock and starts the car).
Any hints or tips?
I've disconnected the battery to see if a soft reset will wake it up.........................this made no difference.
Post #162163 6th Jan 2013 11:33am
Flat car battery?
Post #162174 6th Jan 2013 12:45pm
T24RES
No the battery is all good an S5 changed recently.
Turns out to be 'paranormal' activity. Three cars on the drive, none would open using the remotes.
100yards up the road working as normal. I can only assume some sort of interference. No power lines within miles, i guess if we turn green i'll call for medical assistance Shocked
Post #162214 6th Jan 2013 5:08pm
Nomad
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Zermatt Silver
With my old P38 Range Rover I had similar issues. It is well documented that wireless weather stations that a lot of people have installed in their gardens can interfere with the remotes. The solution was to use the remote fob right up against the antenna in the rear quarter light window. Not sure where the antenna is on the L322. 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #162224 6th Jan 2013 6:10pm
It can happen, if ethere is another transmitter using the same frequency nearby. I've had the same symptoms before in a car park, no response from the remotes. Was the radio controlled trolley mover or something like that which knocked it out, caused interference on the specific channel that the remotes for the cars use.
Have you got a house alarm or garage remote. Might interfere? There is nothing that can't be fixed with a hammer😜😜
Post #162334 6th Jan 2013 10:48pm
sporadic frequency interference...happens a lot in supermarket carparks and one day its a problem and the next it miraculously disappears..... ... - .- -.
Post #162363 7th Jan 2013 10:06am
Nomad
It's true that sporadic interference happens almost anywhere but with my old P38 it was constant at home which was a real pain. As I mentioned the solution was to put the remote fob next to the antenna in the rear side window to open the car (not ideal but at least it worked). Anyone know if the L322 key fob antenna is in the same place for future reference? 2012 5.0L S/C
Previous:
3.6 TDV8
4.4 HSE
P38 4.6 HSE
Classic 3.9
90 County
Series3 Lightweight
Post #162373 7th Jan 2013 10:17am
T24RES
I'm not sure what was causing it but today, all the cars are working fine Thumbs Up I would have chalked it up to FFRR character traits but the other cars were affected too Whistle
Post #162496 7th Jan 2013 6:08pm
just a thought Ian, your tetra maybe? ... - .- -.
Post #162497 7th Jan 2013 6:09pm
T24RES
Wink Stan, thats stays in the office along with the work mobile............
Post #162531 7th Jan 2013 7:06pm
ahh, its not that then... Thumbs Up ... - .- -.
Post #162532 7th Jan 2013 7:07pm
