![]() | Home > Technical (L322) > MY08 Key fob buttons not operating lock/unlock/boot---sorted |
Flat car battery? |
T24RES Member Since: 22 Nov 2010 Location: Henley-on-Thames Posts: 936 ![]() ![]() |
No the battery is all good an S5 changed recently.
Nomad Member Since: 26 Oct 2011 Location: Ringwood, Hants Posts: 300 ![]() ![]() ![]() |
With my old P38 Range Rover I had similar issues. It is well documented that wireless weather stations that a lot of people have installed in their gardens can interfere with the remotes. The solution was to use the remote fob right up against the antenna in the rear quarter light window. Not sure where the antenna is on the L322. 2012 5.0L S/C
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
It can happen, if ethere is another transmitter using the same frequency nearby. I've had the same symptoms before in a car park, no response from the remotes. Was the radio controlled trolley mover or something like that which knocked it out, caused interference on the specific channel that the remotes for the cars use.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35771 ![]() ![]() |
sporadic frequency interference...happens a lot in supermarket carparks and one day its a problem and the next it miraculously disappears..... ... - .- -.
It's true that sporadic interference happens almost anywhere but with my old P38 it was constant at home which was a real pain. As I mentioned the solution was to put the remote fob next to the antenna in the rear side window to open the car (not ideal but at least it worked). Anyone know if the L322 key fob antenna is in the same place for future reference? 2012 5.0L S/C
I'm not sure what was causing it but today, all the cars are working fine |
just a thought Ian, your tetra maybe? ... - .- -.
ahh, its not that then... |
