Home > Maintenance & Mods (L322) > Battery??
VMPP
Portugal 2007 Range Rover Vogue TDV8 Buckingham Blue
Battery??
Hi all
Had a few issues during the past months with the car.
First one, one of these days, the passenger door lock didn't open (not an extreme cold problem as we don't have that over here)
Second, the rev counter sometimes seems to go bonkers, even though the engine is running ok. The other day was idling at 300 rpms, and other time at 1500 rpm.
Yesterday, before starting the car, went to the ''753 code'' and saw that the battery was reading 11.5-12v. Then it's running 12-13v after start. (my idea is that it should charge at 14v)
So question is, are those issues above signs that the battery is going to pack up?
Post #162398 7th Jan 2013 11:46am
how long have you had the battery?..iif over 3'ish years then it could be the first signs..
you're right in thinking it should be about 14 volts on idle... ... - .- -.
Post #162400 7th Jan 2013 12:03pm
mzplcg
13 volts when running sounds more like impending alternator failure. If the battery still has enough to start the car then it's probably OK although it won't stay that way if it doesn't get charged properly.
Post #162585 7th Jan 2013 7:29pm
Tuts
tested mine the other day. was 12.2v not running and 14v running and I have started having issues at these values so pretty sure yours is too low. 2003 Vogue 4.4 V8 Java Black
Post #162592 7th Jan 2013 7:42pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
needs to be 12.5v not running, the 14v at idle is not too bad if thats under load. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #162598 7th Jan 2013 7:58pm
VMPP
The car is now 6 years old, still with the original battery.
One of the very earliest TDV8's.
Post #162606 7th Jan 2013 8:15pm
comports
United Kingdom 2016 Range Rover Autobiography SDV8 Mariana Black
I would do yourself a favour and order a new one up. The day you really need the car will be the day it finally gives up on you.! Ash
2022 SDV8 AB
2016 TDV8 VSE
2011 TDV8 VSE
2006 V8 Vogue
2002 2.5 Vogue
Post #162608 7th Jan 2013 8:24pm
At 6 years old you definitely need a new battery.
From what you describe you may also have an issue with your alternartor.
Start the engine, run at 2000-2500rpm, you should get about 14V+.
If not, wait until new battery is fitted and try the same again.
If you don't achieve 14V you need to have your alternator checked.
Post #162621 7th Jan 2013 9:06pm
VMPP
Will do that test tomorrow, as that alternator options seems very likely. If i remember, in the first year there was an issue with the alternator bearing, but at the time didn't experienced any problems.
But as the car is asking for the yearly service, will have everything checked.
Thanks for all your help guys... Thumbs Up
Post #162668 8th Jan 2013 1:41am
JohnnyDangerous
You need to get a proper multimeter on it, mine reads 13.6-8 no load as soon as the lights are switched on it dips to 12.7 and comes back up slowly, under full load it dips to 11.9 and rises as the revs come up, this is no good but the ign light does not come on and it starts fine (but is a petrol) Dont forget to not just check at the battery also check at the bulkhead connection and at the +ve coming out of the alternator as you may have a bad lead. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #162669 8th Jan 2013 2:52am
