Home > Maintenance & Mods (L322) > Battery?? |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34924 |
how long have you had the battery?..iif over 3'ish years then it could be the first signs..
7th Jan 2013 1:03pm |
13 volts when running sounds more like impending alternator failure. If the battery still has enough to start the car then it's probably OK although it won't stay that way if it doesn't get charged properly. |
7th Jan 2013 8:29pm |
Tuts Member Since: 24 May 2012 Location: Bishop’s Stortford, Herts Posts: 201 |
tested mine the other day. was 12.2v not running and 14v running and I have started having issues at these values so pretty sure yours is too low. 2003 Vogue 4.4 V8 Java Black |
7th Jan 2013 8:42pm |
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 |
needs to be 12.5v not running, the 14v at idle is not too bad if thats under load. One day your life will flash before your eyes......................................make sure yours is worth watching!
7th Jan 2013 8:58pm |
VMPP Member Since: 12 Jul 2009 Location: Lisboa Posts: 410 |
The car is now 6 years old, still with the original battery.
7th Jan 2013 9:15pm |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1656 |
I would do yourself a favour and order a new one up. The day you really need the car will be the day it finally gives up on you.! Ash
7th Jan 2013 9:24pm |
nicedayforit Member Since: 11 Jun 2011 Location: Beside the Solway Posts: 3954 |
At 6 years old you definitely need a new battery.
7th Jan 2013 10:06pm |
8th Jan 2013 2:41am |
You need to get a proper multimeter on it, mine reads 13.6-8 no load as soon as the lights are switched on it dips to 12.7 and comes back up slowly, under full load it dips to 11.9 and rises as the revs come up, this is no good but the ign light does not come on and it starts fine (but is a petrol) Dont forget to not just check at the battery also check at the bulkhead connection and at the +ve coming out of the alternator as you may have a bad lead. One day your life will flash before your eyes......................................make sure yours is worth watching!
8th Jan 2013 3:52am |
