Home > Maintenance & Mods (L322) > Headlamp glass removal 2006>
Macdaddy
2003 Range Rover Autobiography 4.4 V8 Java Black
Could do with removing the glass on the front of a 2006 headlamp to clean the inside.
There's around 6 clips on the outside which I've removed but it won't budge, appears like it's stuck with sealant.
Any tips on how to remove? TDV8 HST Sport **Current**
4.4 V8 Autobiography and 22" wheels **Gone**
Post #16254 7th Apr 2010 8:57pm
simonmanx
Isle Of Man 2005 Range Rover Vogue SE Td6 Java Black
it should come apart with a little tease with a screwdriver it only has a rubber seal unless someone used a silicon type sealant if it was changed before but hopefully its just a little pressure required.
Post #16255 7th Apr 2010 9:00pm
I presume they are the same construction as the RRS, if so then you will not be able to take them apart, they are a sealed unit. the only way I heard of it being done (for bling purposes) was to stick them in the oven to warm the glue that holds them together. Was it worth it? Would they be fully waterproof afterwards? Who knows.
I have dead flies inside my front lenses, sod it, life's too short.... Discovery 4 HSE
1993 90 Tdi
Post #16256 7th Apr 2010 9:11pm
Macdaddy
Could be the rubber seals I can see, I'll try using a bit more pressure thanks! TDV8 HST Sport **Current**
Post #16257 7th Apr 2010 9:12pm
simonmanx
i could be wrong but why would there be clips if it was stuck down by manufacturer !!
Post #16260 7th Apr 2010 9:14pm
Macdaddy
They have clips around the outside which suggests they aren't permanantly sealed.
I thought as you say they'd be sealed but perhaps the clips pull the lense tight against the seal. TDV8 HST Sport **Current**
Post #16261 7th Apr 2010 9:15pm
Just my advice, prising them open sounds like a recipe for cracked glass to me and a new headlamp unit is not cheap.
I checked RAVE and there's nothing about taking the headlamps apart, just removal and bulb replacement.
Good luck! Shocked Discovery 4 HSE
1993 90 Tdi
Post #16262 7th Apr 2010 9:17pm
simonmanx
try spraying a silicone oil type spray around seal then leave a while and see if it helps them seperate ??
Post #16263 7th Apr 2010 9:20pm
daveo
if that dont work try a hair dryer and warm them up, that always works with my rear view mirror on my van in the summer Laughing V8 facelift Range Rover Autobiography 22" wheels.
Post #16267 7th Apr 2010 11:34pm
Macdaddy
Thanks will try those things, don't want to be too forceful and break the lense. TDV8 HST Sport **Current**
Post #16272 8th Apr 2010 7:29am
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
If you just want to remove small debris, use a long chopstick with UHU Patafix or similar on the tip through the bulb removal opening - it's what I did on mine!
Post #16273 8th Apr 2010 7:50am
Or, remove the whole part from the car, take out the bulbs and then stick a vacuum cleaner hose in the bulb hole to suck out debris.
If the lense is dirty inside then you've got a duff one letting in water and dirt. Discovery 4 HSE
1993 90 Tdi
Post #16274 8th Apr 2010 8:18am
hoppy_70
England 2018 Range Rover Autobiography 2.0 PHEV Loire Blue
I agree with RRUK. Don't try to force it cos it will definately break. The RRS lot take theirs apart to colour code the plastic bit inside (a bit purist!). They can be seperated - pasted from another site:
"315 degrees in the oven for 8 minutes actually works. It might be a good idea to take out the bulbs too. You need to put the headlight on really strong cardboard paper so that it doesn't melt on metal. When you take it out, it will be hot so you need to use a thin rag. Then try to split the cover with a flat head screwdriver. "
I personally wouldn't risk this unless the problem bothered me that much that I was considering replacing the lamp anyway (then you'd have nothing to lose!)
Good luck if your going to chance it! Shocked
Post #16319 8th Apr 2010 6:15pm
Macdaddy
I try in the first instance then to remove the bulbs and clean the glass through the holes, If that doesnt work i'll try the removal of the lense.
I'll keep you posted how i go on tommorrow Wink TDV8 HST Sport **Current**
Post #16344 9th Apr 2010 8:41am
verydisco
Hello
I did this on my Disco a while ago :
http://www.disco3.co.uk/forum/topic36286.html?highlight=headlamp
The principle is the same on most current vehicle headlamps, including 2006-on L322 (on 2002 to 2005, clips where doing the job, and on 2009-on there is no more clips, such as on 2009-on RRS and D4. - I guess the glue technology has evolved, leading to not secure it all with clips at all)
This works, headlamps where watertigh still after the operation (tested in real life conditions !)
The US L322 forum had a few guys color coding the 2006-2009 headlights with this technique.
Post #81758 16th Sep 2011 12:59pm
