![]() | Home > Maintenance & Mods (L322) > Headlamp glass removal 2006> |
simonmanx Member Since: 17 Feb 2010 Location: Isle of Man Ballasalla Posts: 157 ![]() ![]() ![]() |
it should come apart with a little tease with a screwdriver it only has a rubber seal unless someone used a silicon type sealant if it was changed before but hopefully its just a little pressure required. |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6374 ![]() ![]() ![]() |
I presume they are the same construction as the RRS, if so then you will not be able to take them apart, they are a sealed unit. the only way I heard of it being done (for bling purposes) was to stick them in the oven to warm the glue that holds them together. Was it worth it? Would they be fully waterproof afterwards? Who knows.
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
Could be the rubber seals I can see, I'll try using a bit more pressure thanks! TDV8 HST Sport **Current**
i could be wrong but why would there be clips if it was stuck down by manufacturer !! |
They have clips around the outside which suggests they aren't permanantly sealed.
Just my advice, prising them open sounds like a recipe for cracked glass to me and a new headlamp unit is not cheap.
try spraying a silicone oil type spray around seal then leave a while and see if it helps them seperate ?? |
if that dont work try a hair dryer and warm them up, that always works with my rear view mirror on my van in the summer |
Thanks will try those things, don't want to be too forceful and break the lense. TDV8 HST Sport **Current**
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 841 ![]() ![]() ![]() |
If you just want to remove small debris, use a long chopstick with UHU Patafix or similar on the tip through the bulb removal opening - it's what I did on mine! |
Or, remove the whole part from the car, take out the bulbs and then stick a vacuum cleaner hose in the bulb hole to suck out debris.
hoppy_70 Member Since: 04 Apr 2010 Location: Peoples Republic of Mancunia! Posts: 870 ![]() ![]() ![]() |
I agree with RRUK. Don't try to force it cos it will definately break. The RRS lot take theirs apart to colour code the plastic bit inside (a bit purist!). They can be seperated - pasted from another site:
I try in the first instance then to remove the bulbs and clean the glass through the holes, If that doesnt work i'll try the removal of the lense.
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 ![]() ![]() ![]() |
Hello
