Home > Maintenance & Mods (L322) > NSF Air Bag Leaking
SteveMFr
Site Sponsor
Don't wanna say I told you so, but.... Laughing
Glad to see you joining the club!
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #162066 5th Jan 2013 8:01pm
mjdronfield
Cheers Steve.
I was hoping it'd be "OK" for a few days, and raise when the engine was started, but the bodyshop would have been moving it about a bit.
Have the car booked in with a Land Rover specialist in Sheffield on Wednesday. Earliest I could get.
The 2 x Delphi struts have already been delivered - thanks Dan.
I charged the battery up earlier, but its still the same. Was a long shot I know.
Have just downloaded the IIDTool manual.
Take it I'm best connecting it to a PC first and updating etc before I connect it to the car for the first time ?
Looking forward to being able to activate park heat......... 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #162070 5th Jan 2013 8:13pm
mjdronfield
Car been in the garage today, 2 new struts fitted. £132 all in. (I supplied the parts)
Got IID Tool at lunch time also.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #163113 9th Jan 2013 8:33pm
not a bad price that...have fun with the IIDTool.. ... - .- -.
Post #163114 9th Jan 2013 8:37pm
mjdronfield
Apparently during transit from Dan, someone had dropped one of the strut boxes on its end, which broke the bit that holds the 3 bolts "captive" where it comes through the wing in the engine bay, so the garage had to tack weld them to stop them spinning to fasten the nuts on, so not a bad price all in all.
Will use them again. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #163118 9th Jan 2013 8:47pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Those top bolts are only supposed to be tightened to 40 odd ft /lbs. Sounds like the garage snapped one of them off throught over tightening. Just done mine y/d and if your packaging was anything like mine, there is no chance they could drop the box and break one off. Atleast they sorted it though . MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #163573 11th Jan 2013 8:19am
T111RDY
Scotland 2002 Range Rover Vogue 4.4 V8 Java Black
Has anyone used the Dunlop ones rather than the Delphi?
Any thoughts/comments?
I also have a leaking NSF Air Bag leaking... Big Cry l:OolΞΞΞΞΞΞloO:l
2002 4.4 Vogue Java Black
Post #168419 29th Jan 2013 2:34pm
woodchopper23
Fitted two to mine last week. Seem fine fit perfect MY2010 TDV8 Vogue Ipanema Sand
Post #168426 29th Jan 2013 2:46pm
T111RDY
Cheers! Thumbs Up l:OolΞΞΞΞΞΞloO:l
Post #168438 29th Jan 2013 3:20pm
Yes we have fitted them recently without any issue Thumbs Up
Post #168466 29th Jan 2013 5:26pm
T111RDY
Did those of you that have replaced these recently have to replace the bolts also?
Part number appears to be KYG000031?
Cheers! l:OolΞΞΞΞΞΞloO:l
Post #168468 29th Jan 2013 5:33pm
No but they are often seized into the hub assy and can be a real b Censored h.... Make sure the strutt top mounting three threads are clean of rust before you undo them as they can be a pain too Thumbs Up
Post #168479 29th Jan 2013 6:27pm
T111RDY
Ok - thanks! l:OolΞΞΞΞΞΞloO:l
Post #168739 30th Jan 2013 10:20am
T111RDY
Parts have arrived - ready for fitting on Saturday! (Weather permitting Confused Supposed to be sunny...)
Will give all the bolts a good soaking with WD40 tomorrow.
In the meantime, have picked up a HDC Inactive / Air Suspension Inactive / Speedo not working fault Big Cry
Thought it might be airbag related, as I was still driving it but trusty IIDTool says Rear Left Wheel Speed Sensor Open Circuit - guessing the sensor needs cleaned / replaced Rolling Eyes l:OolΞΞΞΞΞΞloO:l
Post #169121 31st Jan 2013 2:28pm
