Home > Maintenance & Mods (L322) > NSF Air Bag Leaking |
Don't wanna say I told you so, but....
5th Jan 2013 8:01pm |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7651 |
Cheers Steve.
5th Jan 2013 8:13pm |
Car been in the garage today, 2 new struts fitted. £132 all in. (I supplied the parts)
9th Jan 2013 8:33pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 34962 |
not a bad price that...have fun with the IIDTool.. ... - .- -.
9th Jan 2013 8:37pm |
Apparently during transit from Dan, someone had dropped one of the strut boxes on its end, which broke the bit that holds the 3 bolts "captive" where it comes through the wing in the engine bay, so the garage had to tack weld them to stop them spinning to fasten the nuts on, so not a bad price all in all.
9th Jan 2013 8:47pm |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
Those top bolts are only supposed to be tightened to 40 odd ft /lbs. Sounds like the garage snapped one of them off throught over tightening. Just done mine y/d and if your packaging was anything like mine, there is no chance they could drop the box and break one off. Atleast they sorted it though . MY2010 TDV8 Vogue Ipanema Sand
11th Jan 2013 8:19am |
Fitted two to mine last week. Seem fine fit perfect MY2010 TDV8 Vogue Ipanema Sand
29th Jan 2013 2:46pm |
T111RDY Member Since: 21 May 2012 Location: Dunbar Posts: 187 |
Cheers! l:OolΞΞΞΞΞΞloO:l
29th Jan 2013 3:20pm |
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16188 |
Yes we have fitted them recently without any issue |
29th Jan 2013 5:26pm |
Did those of you that have replaced these recently have to replace the bolts also?
29th Jan 2013 5:33pm |
No but they are often seized into the hub assy and can be a real b h.... Make sure the strutt top mounting three threads are clean of rust before you undo them as they can be a pain too |
29th Jan 2013 6:27pm |
Ok - thanks! l:OolΞΞΞΞΞΞloO:l
30th Jan 2013 10:20am |
Parts have arrived - ready for fitting on Saturday! (Weather permitting Supposed to be sunny...)
31st Jan 2013 2:28pm |
