Home > Technical (L322) > I've got a droopy corner
tsadpt
So I park up tonight, and unusually, I park with the front towards the garage door, when I notice the headlight beam pattern on the near side is about 3/4 inch lower than on the offside.... Confused
So out comes the tape measure, and yes, the near side is lower. Censored Nothing else seems wrong, air suspension works fine (the discrepancy between left and right is the same on any setting), no error messages, and it passed its mot ok in November.
I will have a look tomorrow in daylight, but any ideas? Broken spring? Presume the airbag should be fine since the air seems to be going up and down ok.....
Btw, it's a 2003 with 150,000 miles....
Post #163539 10th Jan 2013 10:42pm
You'll need to give the height sensors a visual first. Might be something obvious there. Previously..
Post #163541 10th Jan 2013 10:49pm
So what is the height difference at the wheel arch compared to the other side. Allow a tolerance of any where between 4 & 10mm. That said, if it is obvious to the eye, then it will offend and need sorting Wink .
Post #163560 11th Jan 2013 12:02am
If your drive is not flat then that will do it! Park it on a known flat area and measure again to be sure before you panic about it...
Craig
Post #163565 11th Jan 2013 1:01am
tsadpt
Thanks everyone! The height I measured was from the ground to the flat part on the top of the bumper, so any slope to the drive should not effect this. What/where are the height sensors? I'll go measure the height of the wheel arches today.....
Post #163636 11th Jan 2013 11:36am
