![]() | Home > Technical (L322) > I've got a droopy corner |
Contraband Member Since: 08 Nov 2010 Location: FIFE Posts: 3700 ![]() ![]() |
You'll need to give the height sensors a visual first. Might be something obvious there. Previously..
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6428 ![]() ![]() |
So what is the height difference at the wheel arch compared to the other side. Allow a tolerance of any where between 4 & 10mm. That said, if it is obvious to the eye, then it will offend and need sorting |
If your drive is not flat then that will do it! Park it on a known flat area and measure again to be sure before you panic about it...
tsadpt Member Since: 09 Feb 2011 Location: West Sussex Posts: 176 ![]() ![]() ![]() |
Thanks everyone! The height I measured was from the ground to the flat part on the top of the bumper, so any slope to the drive should not effect this. What/where are the height sensors? I'll go measure the height of the wheel arches today..... |
