Home > Technical (L322) > Front Diff query
V8 Paul
Front Diff query
Hi all,
I have just registered with a view of being a range rover owner once more. Having owned a P38 and enjoyed smoking round in it, I now want to own a full fat rangie.
I have found one for sale at a trade dealer, although I have not been to see it yet due to distance, I have spoke to the dealer and spoke in length about it, the story is as follows.
Dealer was fixing a couple of small issues before releasing the vehicle which included sorting out the central locking and a window fault, I quizzed about the front diff and the resonse was that his technician works for guy salmon landrover who had checked it over and no outstanding work was neccasary. After a couple of days mulling I phoned him back to secure the vehicle with a few quid, of which he happened to be with his technician, so being a nosy sod decided to chat with him and it came out that the car has not had the diff recall done !!! Also they had found out that the gearbox was playing up after an oil change, the dealer assured me all would be well as he would have the gearbox and have it overhauled. In the mean time leave the front diff to him to investigate.
As you can imagine I came off the phone in a dilemma, so here is/are my questions,
Can the front diff still be recalled and if not how would it be done, I ask in case the dealer makes me a proposition with respect to the price, would it be worthwhile me getting it done or should I look else where.
Secondly does anything specific need doing with a gearbox overhaul, am I looking at a dog of a car or will I be blessed with a "new" gearbox.
Many thanks
Paul
Post #164414 13th Jan 2013 8:12pm
Katash
England 2007 Range Rover Supercharged 4.2 SC V8 Zermatt Silver
IIRC the recall has ended and LR will charge now if requested to do.
Post #164417 13th Jan 2013 8:18pm
bizzybus
United Kingdom 2005 Range Rover Vogue Td6 Zambezi Silver
Could you expect this recall to have been done by dealer if the service records show a service before and after the recall date ??
i ask this as i dont know if mine has been done but have a dealer service record upto 2011 0n 05 vogue, this may also help v8 paul. (SEE WHAT HAPPENS WITH HEATED SEATS)
Post #164418 13th Jan 2013 8:30pm
Katash
Not sure .... Easy enough to tell by looking underneath tho.
I think you can call any LR dealership service department and they will be able to tell you.
Post #164429 13th Jan 2013 8:47pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
speak with Liam in the LR customer relations section, get him to check and if not done ask him what can be done, accorrectly worded mail or letter may have more effect than you may think. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164431 13th Jan 2013 8:48pm
V8 Paul
Thanks guys, with the recall ending and it is now chargeable, how much does this cost to upgrade, it does seem surprising that his vehicle has got to 120k without the mod
Post #164432 13th Jan 2013 8:51pm
JohnnyDangerous
Get reg and vin and get Liam to check and see what recalls have been done. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164434 13th Jan 2013 8:53pm
Katash
I have read quite a few threads that suggest the recall was due to an incorrectly lined up prop shaft during assembly, this usually manifests itself as a destroyed front diff or stripped shaft - evident usually <60k
Not all actually needed the recall - if the alignment was correct to start with then there is no problem, infact some people have reported disturbed seals & oil leaks after the recall work.
Post #164447 13th Jan 2013 9:20pm
steptoe
Nothing to do with alignment - it's the lack of any flexibilty on the coupling on the front shaft at the diff.
Old shaft coupling
New shaft coupling .
Post #164480 13th Jan 2013 10:30pm
Katash
Take a look here
http://www.autoblog.com/2008/12/05/nearly-...-recalled/
This and numerous other sources clearly state its due to miss alignment of the prop shaft.
If it was lack of flexibility then ALL cars would eventually fail, results suggest if you have a 'bad one' its will have failed early, if you've done > 60K there is no need for the mod as the shaft isn't miss aligned.
Post #164487 13th Jan 2013 11:07pm
JohnnyDangerous
Hmmmm manufacturers are always pretty cagey about stuff, a bit strange why they did not replace the prop and diff with the same type if there wasn't a design fault in the first place and align them correctly. More to the point is the statement
Consequence:
CONTINUED VEHICLE OPERATION CAN EVENTUALLY RESULT IN THE SPLINES SHEARING AND A LOSS OF DRIVE, INCREASING THE RISK OF A CRASH.
How on earth can LR refuse to change a part that can cause by their own admission A CRASH. I was doubting if mine had been done (Liam checked and it has had all its recalls) but if it had not I was going to get my daughter who is just about to qualify as a Lawyer to write a strong letter that would basically ask LR to take full responsibilty for any outcome of a crash or lock up at motorway speed. She explained it was almost immpossible for them to reply and avoid any liability.
As regard the reason for the re-call i would just say IMO dont believe everything you read. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164526 14th Jan 2013 9:10am
steptoe
Katash wrote:
Take a look here
It wasn't just an alignment problem - It was lack of flexibility at the joint. If the vehicle was only ever used on flat surfaced roads and never taken off road you'd never have a problem.
This was the fix - Fit redesigned parts incorporating a CV joint at the front end as well as the existing flexible joint at the rear. This brought the design into line with the one used on the 2006 & up.
More info here - Look under "Differential Failure"
http://www.rangerovers.net/rrmkiiiremedies.html#diff
Post #164541 14th Jan 2013 10:21am
Katash
I agree the CV joint is the best way to go and does allow flexibility but your original statement Steptoe saying it had nothing to do with alignment is just plain incorrect.
Your link even contains the following text
Quote:
It is well-known that some past BMW vehicles have had problems with drive shafts (propeller shafts or "prop shafts" in Queen's English) being misaligned causing spline wear and breakage in the differential. Since the new RR was designed by this manufacturer, it is possible that a similar issue is at work here.
and
Quote:
in 2004 Land Rover issued a special jig to dealers for aligning the front diff and supposedly eliminating the problem.
OP you now have a predicament (assuming yours has not been done, which to be honest if it has a full LRSH and the owner was written to regarding the issue I'd say its probably been done) .... Do you insist it is put right or leave it.
Post #164545 14th Jan 2013 10:41am
RRPhil
Probably worth pointing out that, because the L322 has independent front suspension, neither end of the front propshaft moves in space, no matter what the suspension is doing. The final drive assembly is bolted to the engine sump – and is therefore part of a rigid assembly, through the engine and transmission, back to the transfer box.
The spline wear issue was caused by levels of angular misalignment between the external spline on the end of the propshaft and the internal spline in the pinion drive tube which were beyond what the flexible coupling at the transfer box end of the front propshaft could cope with. The introduction of a second joint at the final drive end of the propshaft, with Q041, cured this.
The clearance in the four bolt holes that attach the final drive to the sump is what allowed this misalignment to materialise.
Phil
Post #164593 14th Jan 2013 2:12pm
JohnnyDangerous
So basically a design fault? One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164598 14th Jan 2013 2:20pm
