![]() | Home > Technical (L322) > Front Diff query |
Katash Member Since: 10 Apr 2011 Location: Hereford Posts: 700 ![]() ![]() ![]() |
IIRC the recall has ended and LR will charge now if requested to do. |
bizzybus Member Since: 19 Aug 2012 Location: merseyside Posts: 53 ![]() ![]() ![]() |
Could you expect this recall to have been done by dealer if the service records show a service before and after the recall date ??
Not sure .... Easy enough to tell by looking underneath tho.
JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833 ![]() ![]() ![]() |
speak with Liam in the LR customer relations section, get him to check and if not done ask him what can be done, accorrectly worded mail or letter may have more effect than you may think. One day your life will flash before your eyes......................................make sure yours is worth watching!
V8 Paul Member Since: 13 Jan 2013 Location: Sheffield Posts: 7 ![]() ![]() |
Thanks guys, with the recall ending and it is now chargeable, how much does this cost to upgrade, it does seem surprising that his vehicle has got to 120k without the mod |
Get reg and vin and get Liam to check and see what recalls have been done. One day your life will flash before your eyes......................................make sure yours is worth watching!
I have read quite a few threads that suggest the recall was due to an incorrectly lined up prop shaft during assembly, this usually manifests itself as a destroyed front diff or stripped shaft - evident usually <60k
steptoe Member Since: 23 Jul 2012 Location: london Posts: 382 ![]() ![]() |
Take a look here http://www.autoblog.com/2008/12/05/nearly-...-recalled/ This and numerous other sources clearly state its due to miss alignment of the prop shaft. If it was lack of flexibility then ALL cars would eventually fail, results suggest if you have a 'bad one' its will have failed early, if you've done > 60K there is no need for the mod as the shaft isn't miss aligned. |
Hmmmm manufacturers are always pretty cagey about stuff, a bit strange why they did not replace the prop and diff with the same type if there wasn't a design fault in the first place and align them correctly. More to the point is the statement
It wasn't just an alignment problem - It was lack of flexibility at the joint. If the vehicle was only ever used on flat surfaced roads and never taken off road you'd never have a problem. This was the fix - Fit redesigned parts incorporating a CV joint at the front end as well as the existing flexible joint at the rear. This brought the design into line with the one used on the 2006 & up. More info here - Look under "Differential Failure" http://www.rangerovers.net/rrmkiiiremedies.html#diff |
I agree the CV joint is the best way to go and does allow flexibility but your original statement Steptoe saying it had nothing to do with alignment is just plain incorrect.
and
OP you now have a predicament (assuming yours has not been done, which to be honest if it has a full LRSH and the owner was written to regarding the issue I'd say its probably been done) .... Do you insist it is put right or leave it. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1033 ![]() ![]() |
Probably worth pointing out that, because the L322 has independent front suspension, neither end of the front propshaft moves in space, no matter what the suspension is doing. The final drive assembly is bolted to the engine sump – and is therefore part of a rigid assembly, through the engine and transmission, back to the transfer box. ![]()
The spline wear issue was caused by levels of angular misalignment between the external spline on the end of the propshaft and the internal spline in the pinion drive tube which were beyond what the flexible coupling at the transfer box end of the front propshaft could cope with. The introduction of a second joint at the final drive end of the propshaft, with Q041, cured this.
The clearance in the four bolt holes that attach the final drive to the sump is what allowed this misalignment to materialise. ![]() Phil Admin note: this post has had its images recovered from a money grabbing photo hosting site and reinstated ![]() |
So basically a design fault? One day your life will flash before your eyes......................................make sure yours is worth watching!
