Home > My Range Rover > Carbon
Page 2 of 3 <123>
spanner
purchased knobs from land rover and changed them
Post #164435 13th Jan 2013 9:54pm
daveo
was it direct from the dealer as i bought a few from landrover parts on ebay but they was just to small to go over, i take it you done the same to the ciggi lighter V8 facelift Range Rover Autobiography 22" wheels.
Post #164440 13th Jan 2013 10:14pm
Jr-auto-electrics
England 2004 Range Rover Vogue Td6 Java Black
You wouldn't have the part numbers would you.
Didn't think they sold them separately RANGE ROVER 04 TD6
RANGE ROVER ULTIMATE EDITION 2012
UPGRADE.
MK 4 SATNAV
http://www.flickr.com/photos/jrautoelectrics/
Post #164450 13th Jan 2013 10:24pm
JohnnyDangerous
England 2002 Range Rover Vogue 4.4 V8 Java Black
If you have the part numbers Ill get a set as well, they look well smart. One day your life will flash before your eyes......................................make sure yours is worth watching!
Post #164466 13th Jan 2013 10:49pm
Did mine a while ago too Thumbs Up
Used the knobs off some broken 07/08 heater panels on my nav and EAS switch's
Craig Thumbs Up
Post #164486 13th Jan 2013 11:56pm
daveo
dont think you can buy them direct from the dealers tried when i first see them on a S/C, ended up getting the complete unit, so what did you mob,the knob or the switch.. V8 facelift Range Rover Autobiography 22" wheels.
Post #164492 14th Jan 2013 1:43am
spanner
You have to turn the exsisting knob down to accomodate the new knob is quite easy then clip the new one on the cigar lighter is a switch for my surround cameras I have 4
Post #164501 14th Jan 2013 8:44am
daveo
how much did you take of, small amount and do it with switch in situ or a large amount and had to remove switch panel..i take it we are talking a dremel. V8 facelift Range Rover Autobiography 22" wheels.
Post #164505 14th Jan 2013 8:56am
spanner
Yes take them out I used a lathe
Post #164507 14th Jan 2013 9:01am
So they cannot be purchased separately?
Post #164509 14th Jan 2013 9:07am
Nice job can we see pictures of the exterior?
Post #164510 14th Jan 2013 9:10am
spanner
will do when weather is better Smile
Post #164721 14th Jan 2013 8:08pm
daveo
so when you turned it down you loose the 2 lugs that stick out...how did you mount it in the lathe V8 facelift Range Rover Autobiography 22" wheels.
Post #164737 14th Jan 2013 8:31pm
spanner
Hi Daveo yes just cut the lugs off then mount in lathe using the stubby shaft then turn down to 24mm
Post #164857 15th Jan 2013 8:06am
johnboyairey
Re: Carbon
spanner wrote:
Decided to enlarge my carbon footprint
hi, that looks fantastic, what is a typical price to do these parts, ie all the parts in these pictures, if i removed mine and 'sent then in' please.
Post #176978 11th Mar 2013 1:17pm
Page 2 of 3 <123>
