![]() | Home > My Range Rover > Carbon |
| spanner Member Since: 05 Jun 2011 Location: uk Posts: 134 |
purchased knobs from land rover and changed them |
| Jr-auto-electrics Member Since: 15 Jan 2012 Location: West Midlands Posts: 189
You wouldn't have the part numbers would you.
| JohnnyDangerous Member Since: 16 Dec 2012 Location: East Sussex Posts: 833
If you have the part numbers Ill get a set as well, they look well smart. One day your life will flash before your eyes......................................make sure yours is worth watching!
| Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16403
Did mine a while ago too |
| daveo Member Since: 21 Oct 2009 Location: london Posts: 2307
dont think you can buy them direct from the dealers tried when i first see them on a S/C, ended up getting the complete unit, so what did you mob,the knob or the switch.. V8 facelift Range Rover Autobiography 22" wheels.
You have to turn the exsisting knob down to accomodate the new knob is quite easy then clip the new one on the cigar lighter is a switch for my surround cameras I have 4 |
how much did you take of, small amount and do it with switch in situ or a large amount and had to remove switch panel..i take it we are talking a dremel. V8 facelift Range Rover Autobiography 22" wheels.
Yes take them out I used a lathe |
| Gazellio @ Prestige Cars Member Since: 22 Jan 2010 Location: Chilterns, UK Posts: 11309
So they cannot be purchased separately? |
Nice job can we see pictures of the exterior? |
will do when weather is better |
so when you turned it down you loose the 2 lugs that stick out...how did you mount it in the lathe V8 facelift Range Rover Autobiography 22" wheels.
Hi Daveo yes just cut the lugs off then mount in lathe using the stubby shaft then turn down to 24mm |
| johnboyairey Member Since: 11 Jan 2013 Location: surrey Posts: 2035
hi, that looks fantastic, what is a typical price to do these parts, ie all the parts in these pictures, if i removed mine and 'sent then in' please. |
