![]() | Home > Technical (L322) > Temperature display |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 ![]() ![]() ![]() |
thats easy and cheap |
davidalanbatt Member Since: 04 Sep 2009 Location: lancs Posts: 11 ![]() ![]() |
Thanks Andy, I couldnt find the information in the radio handbook but I will have another look. |
just checked i cant do mine either sorry |
Has anyone any more ideas on this one?
jayzee Member Since: 14 Oct 2009 Location: UK Posts: 342 ![]() ![]() |
http://www.justanswer.com/questions/3c9vk-...to-cels-rr
right i did say watch this space and i have gone through rave and this is what it said
Thanks for your help guys. It looks like a trip to the dealers then! |
Fox Member Since: 02 Apr 2010 Location: Essex Posts: 2313 ![]() ![]() |
That's a bit daft isn't it?
I might be wrong....but surely it IS a setting, because you can change the RANGE/LANGUAGE to KM's ... and I'm sure that when you do that, the temp goes to F (It has been a long time since I owned a 4.4 tho....)
you would have thought but i spent 20mins sat with the hand book and sat in the car but no joy so i searched the rave and thats what it said |
I wonder if it works like the Disco II setting then?
Worth a try to see if there is some combo on the FFRR too ![]() XXXXXXXXXXXXXXXXXXXXXXX Previous XXXXXXXXXXXXXXXX 2009 5.0V8SC Autobiography 2006 4.2V8SC Autobiography 2004 4.4V8 Vogue |
Thanks Thrasher, I tried this but my model does not seem to have an off button for the climate control. |
did any one get this changed back to deg c and i have done the same bloody idle hands 02 Range Rover HSE Zambezie silver 4.4 |
Tim in Scotland Member Since: 25 Mar 2007 Location: Somewhere between here and there, if not then I'm all at sea or at home in Scotland Posts: 2181 ![]() ![]() |
Ok try this, bearing in mind it is 6 years since I owned a TD6SE without fancy computers or satnav!) on the LH stalk on the steering column (the silvery tipped one with the "i" carved in it that changes stuff in the driver info screen in the dash), press it in and hold it so it scrolls through the functions to UNITS and IIRC you will find the miles per litre and temperature units change choice. 2018 Mini Countryman Cooper S E All4 PHEV in Melting Silver - itβs whisper quiet in EV and polluter modes |
