![]() | Home > Technical (L322) > Rear seat base removal |
M44K TS Member Since: 09 Feb 2010 Location: North East U.K. Posts: 1325 ![]() ![]() |
I think when you fold the seats forward, there's some carpeted trim which is held on by black plastic push in clips, I dare say if you remove the clips you might be able to get to the back of the seat base.
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 ![]() ![]() ![]() |
Thanks - I'll give that a go tonight ! |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6381 ![]() ![]() |
I would have thought just folding the seats all the way forward will give you access won't it? Discovery 4 HSE
Macdaddy Member Since: 15 Oct 2009 Location: Preston, Lancashire Posts: 466 ![]() ![]() |
As above...
Oh B*gger - that's far too obvious - sounds like a severe vacuum might be required tonight too then - thanks ! |
It nearly worked !
One you have the bases moving - simply smack them on the back and small items will fall out |
Or just use the thin hoover nozzle and suck out whatever is in there. if it's a valuable, empty the hoover first so when you retrieve it from the bag it's not caked in all the rubbish. Discovery 4 HSE
